Old 06-09-2014, 07:22 PM   #1
Checking air pressure on 2014 Forest River Forester
Hi
Is there a solution to checking the air pressure in the front tires without having to remove the wheel covers?
Brand new class C doesn't have TPMS. I have been told that valve extenders aren't going to work as the covers will shift over time due to centrifugal force.
Any suggestions would be appreciated!
Thank you
ARodden is offline   Reply With Quote
Old 06-09-2014, 07:57 PM   #2
RSchleder's Avatar
It really is no big deal taking off the wheel covers, about 30 sec to take off and replace. Best thing is to JUST DO IT!
RSchleder is offline   Reply With Quote
Old 06-09-2014, 08:02 PM   #3
I have metal valve extenders on the front and have no issue at all.
markangie24 is offline   Reply With Quote
Old 07-27-2014, 06:51 PM   #4
I had some metal valve extenders put on at the dealership Friday. I am hopeful they will work fine as well 😊
Old 07-27-2014, 07:53 PM   #5
tmhyer's Avatar
My sunseeker came with valve extenders. Are you sure they're not in there and just turned where you cant see them?
tmhyer is offline   Reply With Quote
Old 07-28-2014, 06:59 PM   #6
No, I'm sure if there had been extenders that were hidden, I would have seen them when I checked the air pressure (prior to having the extenders put on)😉
Old 08-09-2014, 03:04 PM   #7
I put 90 degree valve extenders with no problem.
biznsa is offline   Reply With Quote
Old 09-24-2014, 04:25 PM   #8
how do you take the covers off....i have one tire with a extender and one with out....i have a class c sunseeker
glfairjr is offline   Reply With Quote
Old 09-24-2014, 05:04 PM   #9
2013leprechaun319dsf's Avatar
They just pry off.
2013leprechaun319dsf is offline   Reply With Quote
Old 09-24-2014, 06:44 PM   #10
I used a long flat head screwdriver and a rubber mallet to pry them off. However, since then, I have had valve extenders put on. MUCH easier 😊
2014, forest river, forester, pressure
