Originally Posted by ppine
Wet cell batteries do not last when used often. They should never go below around 12.3-12.4 volts. Consider stepping up to AGM batteries.
again, someone who is espousing supposed information about something that is totally NOT true....
I have four 6v deep cycle RV FLA(Flooded Acid) 'wet cell' batteries in my coach, and they are the 'factory' installed ones from almost 5 years ago, and still going strong - I regularly use them when off-grid and they normally discharge down to 11.8 or 11.9 before I charge them for 30minutes with the generator. They also sometimes automatically cutoff the Inverter when they drop to 11.5 when I don't want the generator to start during overnights.
92,000 miles and many, many overnights off-grid, whether walmart, or Alaska, or a no-hookups campground...
I check the water levels infrequently, and add water as needed.
I'll have to disagree with your 'assessment' of wet cell batteries ...
they are actually the 'best' for RVs, for the money...
