Old 04-23-2015, 08:25 PM   #1
chrismbrock2009's Avatar
Coachman Mirada brake sound
Newbie with a 2015 Coachman Mirada 35BH... previous RV was a Sunseeker 3170.
Question is this... what type of braking system is on my unit? There is a "whine" when I hit the brake peddle. Even when the coach is not running the brake pedal makes a sound.. Cant find any documentation on this..
Thanks in advance
chrismbrock2009 is offline   Reply With Quote
Old 04-24-2015, 01:01 PM   #2
Anyone ?
2015 Coachmen Mirada 35bh
Global Wedding Photographer
Old 04-24-2015, 01:05 PM   #3
Does it make the sound when you are standing still and you press the brake pedal? If so its the pump that does the braking assist. In no then you have a problem.
caesar101 is offline   Reply With Quote
Old 04-24-2015, 01:07 PM   #4
It only makes the sound when using the brake. Even if the ignition is off and I step on the brake it makes a pump running sound.
Old 04-24-2015, 01:21 PM   #5
That would be right, its a Ford F53 motor home? Look near your master cylinder under the hood, there should be a small round pump attached.
Old 04-24-2015, 04:52 PM   #6
Thanks.
Sound threw me off. My 2014 Sunseeker with the Ford v10 didn't make any braking sounds and the steering didn't whine.
This Coachmen also has a whine to the steering in low speeds.
Just checking to make sure this is normal 😉
Old 04-25-2015, 09:54 AM   #7
Driving the Coachmen today and the power steering whine was VERY loud ... is this normal?
Old 04-25-2015, 12:34 PM   #8
Update: so checked the power steering fluid level and it was so low that even after adding 2 small bottles of power steering fluid it still is not registering on the dip stick. Though the whining sound has gone away. I guess back to the dealer this week. Don't they check these things during the PDI? This is a brand new coach with 750 miles on it.
Old 04-25-2015, 12:53 PM   #9
Originally Posted by chrismbrock2009 View Post
...Don't they check these things during the PDI? This is a brand new coach with 750 miles on it.
I think you just answered your own question.
Old 04-25-2015, 06:03 PM   #10
I get that... but geez...
brakes
