02-18-2019, 06:50 PM
Kanadian Kamper
Confirm or deny?
Anyone heard with any certainty that the Ford V10 is on it’s way out as the engine of choice in the gas motorhome market, no matter whose “house” brand is riding on it? Pretty sure that’s all there is after GM Vortec is no more.....if I’ve got that right
A friend said he heard......
I figured I’d ask those that may know better.
Ken and Terry
02-18-2019, 07:32 PM
Recently new!
I do know that Ford is about to release a 7.3 gas engine
(oh the sacrilege!....LOL)
Interesting to see how that works out. Too bad they don’t re-release the 7.3 diesel!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
02-18-2019, 07:54 PM
Video I saw on the new 7.3 gas it's an 8 cylinder. No specs released yet. Article didn't say if it's overhead cam or not.
02-18-2019, 08:46 PM
Recently new!
Ford has been mum on any spec’s on the new 7.3, other than it will have a new 10 speed transmission.
2001 Ford F-250 7.3
02-19-2019, 05:32 AM
That will be a sad day for motorhomes if the V-10 disappears. The saving grace for the V-8 may be the trans. I know the 8.1 GM couldn’t hang, which is why it’s no longer.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-19-2019, 08:58 AM
Citrus County, Fl.
Production of the 2020 E Series is supposed to start in January 2020 which is much later than new model year production usually is so I imagine there is a big change in the works.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
02-19-2019, 09:13 AM
Wont be long and all the OEMs will be doing the same with the transmissions. Better fuel mileage and torque options.
02-19-2019, 09:26 AM
The new 7.3 gas engine will be a pushrod V8. It was designed more narrow than the previous V8's so it could be installed in many different platforms.
02-19-2019, 09:31 AM
There are enough articles if you google "Ford ending V10 engine production" that indicate the V10 is going away. The new engine will start making appearances in the F-Series in Fall 2019. When it will be replaced in the E Series and the F-53 chassis is a question.
02-19-2019, 09:47 AM
Could be their replacing the V-10 with a 4.5 eco boost for the motor coaches LOL
02-19-2019, 10:11 AM
I heard that Ford and GM are getting together to build those 10 speed transmissions.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
02-19-2019, 10:12 AM
I don't know what is going away or coming up--- but--- I had a Ford V-10 in a class C and a GM 8.1 in a class A. I liked the GM 8.1 better, it had better performance and better mpg. Just my experience.
Roger
2024 GMC Denali 2500
2022 Rockwood Ultra Lite 2442BS
KJ6VVB
02-20-2019, 12:10 AM
Recently new!
Onetonford, you did hear correctly.
2001 Ford F-250 7.3
02-24-2019, 01:51 PM
Push rod, cam in block.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
02-24-2019, 03:38 PM
If I’m quoting correctly, an article with ford exe was asked why this size and why push rod. Response was ohc engine makes power on the high end sacrificing fuel economy while push rod makes it down in low rpm, like in motor home use.
I think that’s a yes.
Just glad to get away
03-05-2019, 01:48 PM
7.3 liter with the 10 speed transmission going into the motorhome chassis was confirmed. Said to generate more power and torgue than the current 6.8 engine. Also to get new dash and steering column, along with updated electrical systems and features.
FROG Member
03-05-2019, 05:31 PM
That makes zero sense. The cam profile is what makes the difference. Where the cam is located makes NO difference.
03-05-2019, 10:02 PM
See new thread. Ford confirms adding V8 with a 10 speed transmission for 2020.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
03-06-2019, 06:27 AM
Camper
http://www.forestriverforums.com/for...-a-179971.html
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
03-06-2019, 07:28 AM
I have a 2017 that has the V10. With the $500 5Star ODBC upgrade, there is NOTHING wrong with the Engine or Transmission at all.
Better mileage would be nice, but that is just physics and software can not help that. MPG = (weight / 2800) * 35. It is that simple! Use any of your gas vehicles, put in its weight and the result will be extremely close from my real world tests. I always heard different vehicles, designs, manufacturers, … are different, but reality is that for every gallon of fuel (regardless of type), it yields XX quantity of energy. The higher the mass, the more energy (fuel consumption) it takes to move it. Assuming gearing (Tx) is correct, a smaller engine at higher RPMs will consume the exact same amount of fuel as a larger one at lower RPMs - just physics.
Unless there is a breakthrough in designs (something like Fuel Injection was), all current engines are fairly equal in efficiency regardless of manufacturer. They all use the same design technology in hardware and software and most vehicles shapes are based on some form of wind tunnel input.
