Old 05-10-2018, 04:17 PM   #1
Dash ac
Just purchased a brand new coachmen pursuit. Dash ac not working. Took to a ford dealer in my lil hometown in western nc and found that there's some wires not connected to some plugs on heater box. Can't seem to get much info from where I bought it yet so thought I'd put my feelers out on here. Heres a pic of mine and a pic the dealer sent me of one on their lot.
Anybody have any idea where those wires come from?
Thanks In advance
ID:	171372   Click image for larger version
52chevy is offline   Reply With Quote
Old 05-10-2018, 07:34 PM   #2
The wires should be coming from the dash controls. When you select the AC mode the relay should kick in the compressor and the top wires will kick it out when the unit gets to cold and starts icing up. Most likely the wiring harness is try wrapped up with some of the wiper harness.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 05-10-2018, 07:45 PM   #3
I will look into that in the morning, at least an option. I really didn't have an idea where to start.
Old 06-19-2018, 07:05 AM   #4
Dash ac
Go to the Evans Tempcon website. There are excellent troubleshooting guides there to get you started.
Also check out the FR3 forum here as another person was also having dash AC troubles.
Note the dash AC has components from Ford and Evans, then these are shoehorned into the RV by the RV builder, in this case FR.
vjstangelo is offline   Reply With Quote
Old 07-07-2018, 01:24 PM   #5
Iggy's Avatar
Here is some docs I have.
File Type: pdf EVANS TYPICAL ELECTRONIC ROTARY WIRING DIAGRAM.pdf (290.6 KB, 9 views)
File Type: pdf Evans%20Parts%20VS%20Ford%20Parts[1].pdf (94.1 KB, 6 views)
2012 Georgetown XL - 378TS 73K miles
Life is a journey, not a destination
Old 07-07-2018, 01:28 PM   #6
Iggy's Avatar
Also here are two pics but won't show much other than the blue wires and the hot water valve.
ID:	178602   Click image for larger version
