It sounfds like at least two problems. Water in and water out are ypically separate systems unless there is a very atypical set up.
Back up in drains
Is you gray water tank full? I don't know why else two drains would back up at the same time.
Gurgling
It could be water running into the water heater. That takes a while and will gurgle. In my experience, this is most likely.
It could be filling up your freshwater tank if the check valve in the water pump is bad. Check the drain on the fe tank. Is it getting water in it?
Hope that helps
