12-20-2010, 11:06 PM
marialee-Berkshire410qs
Dead Batteries
Hubby went out to check the 2011 Berkshire 410qs and all the house batteries are dead!!! We have a battery charger and it stated that they were bad. Only have had MH for over 1mo. What would make them all go bad? Any suggestions?
12-20-2010, 11:44 PM
Moderator
Well, let me take a stab at this. You assume a new Motor home came with new batteries. May not be true. You assumed they were fully charged when you bought the motor home. May not be true.
Now if the motor home has been parked, and not plugged in, it will kill the batteries in a month, especially if a light or the radio was left on. There are things that draw current from the batteries when not in use.
Get a voltmeter and measure the battery voltage. If it is below 5 volts, most newer battery chargers won't work to charge them up. Fire up the generator, and measure the battery voltage with the generator running, and it should slowly climb to over 13. ( the generator needs to be run once a month anyway.) After 30 minutes, shut the generator off, and measure battery voltage, should still be over 12.5 volts. Check them 24 hours later, and hope for more than 12 volts.
While the generator is running, go in the motor home and check for lights left on, radio, refer, furnace, and other stuff.
Don't blame the batteries just yet.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
12-21-2010, 07:10 AM
The carbon monoxide detector in our trailer will kill the batteries in no time, as it seems to pull a lot of juice. I disconnect the batteries whenever it sits for more than a day.
12-21-2010, 07:39 AM
volunteer moderator
Like others have said, don't blame the batteries just yet.
IF they are totally discharged you might have to use an external
battery charger to get them started or at least partially charged.
On-board items like the LP gas and possibly the carbon monoxide
detector can drain your batteries. The on-board power center
(battery charger) built in my trailer also is a slow drain when
the trailer is not plugged in.
For this reason I added a battery disconnect switch WHICH SHOULD
BE STANDARD EQUIPMENT in all RVs. Ahem.....'scuse me as you
can see this is a sore spot with me.
You are only one in a LONG line of RVers who have found their
brand new RV has dead batteries after just a brief spell of storage.
I installed my switch in the toe kick area right next to my
fuse box/power center. This required only a very short piece
of extra wire and one hole in the baseboard. Since I have some
electrical experience it was an easy (1 beer) job ;-)
Go to Amazon.com and search for
battery switch.
I have the top one on that page.
Maybe you can install it or maybe you have an experienced neighbor or
maybe your dealer will do it for a reasonable price.
It's a good "upgrade" and will save your batteries.
Once we return home from a trip and the fridge has been
emptied and dried and everything put away that needs
it, we shut off the battery disconnect.
This shuts off EVERYTHING including the LP gas detector.
My LP tanks are shut off at this point so I am not worried.
Our smoke and CO detectors are not in the house
battery circuit. They have their own (AA or 9V) batteries.
For your consideration-- I also use a "battery tender Jr."
while my trailer is parked at home. This little device keeps
my batteries at full charge all the time.
Keeping your batteries at full charge is the best way to extend their
lives and it means we are always ready to go battery wise.
Good Luck!!
Peace!
Dan & Rita D
2008 Rockwood 2502 Ultra Lite
2004 5.3L Silverado 1500 ext. cab 2WD
Reese dual cam hitch, AirLift load levelers
53 days camping in 2010, 47 in 2011, 12 in 2012
12-21-2010, 07:40 AM
Lou Amadio
Well the bad news.
Once the batteries are dead; there is no freeze protection.
The Sulphuric Acid in the battery is what protects it from freezing.
A discharged battery has all the Sulfate plated on the lead cell walls and there is only a very weak acid left to protect the water (Specific Gravity close to 1.00 pure water).
If the water in the battery freezes it can: bulge/crack the plastic case and cause the electrolyte to leak out; crack the lead plates in one of more cells; or cause an internal short that will prevent charging.
Replacement is your only option for a battery that froze. Pulling it out and taking it to a battery shop will verify the battery condition.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
01-03-2011, 10:39 PM
CampeRooo
Originally Posted by herk7769
Well the bad news.
I feel very lucky after reading your post. I went out to check the battery on my TT, just like I do every month, and the meter on the wall didn't register anything. So I thought, well, I'm going to be giving the Bronco a tuneup today, so I'll just plug it into the garage circuit and let the converter do it's job. After about an hour, I went back in to check to see that it was indeed charging and guess what...nothing. Checked all the connections again, still not charging. Pulled the mainline and took my external charger out and set it up to start charging. 9 hours later at 2A, i'm back up to 91% and still going. Interesting that the converter wouldn't bring it off the bottom, but the external charger would. But that's not what makes me feel lucky...I feel lucky because we've had single digit temperatures here in N. Colorado for the last few days and on some occasions, below zero during that pre-sunrise time. Battery isn't bulging or cracking and is taking a charge. Whoa!
(Although, had it gone belly up, that would have given me the perfect excuse to tell the wife I need to go shopping for new 6V batteries for the trailer.  )
All's well that ends well.
Joe
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
01-03-2011, 11:31 PM
Lou Amadio
So glad they are taking a charge. Hopefully no internal damage was done. I would keep an eye on them and see if they work as well as they used to.
01-04-2011, 07:01 AM
rthrbelsewhere,
I understand everything except the part that you feel lucky that it got down to single digits the last few nights ?
01-04-2011, 07:30 AM
volunteer moderator
Originally Posted by peskin
rthrbelsewhere,
He's feeling lucky that his batteries didn't freeze and burst.
Dead lead/acid batteries can freeze and split wide open.
Fully charged lead/acid batteries won't do that. That's why
it's so important to keep them charged especially in winter.
01-04-2011, 07:37 AM
Lou Amadio
Dan,
I know its early!
You need another cup of Joe! Wake up!
I think that was a joke.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 552 |
| 94 members and 458 guests |
| 4runner freak, 5Galvs, amxpress, ayotte, biggie, bikeman911, BlakeB, bob213, bob34787, Bob_Loblaw, buckeyefan, Buffalohunter, camper_Lucy, Canuck_Doug, Cascade Bob, cbconway, cdbus, CHD Dad, cousin01, cstover, danred, DAREK.NIEUWSMA, daveg, daveinpickerington, ddurnell, dimurrrw, dknight903, DonG, donn, Doug DiLaura, dstwilsons, dunnnc, fonzie, GAS MAN, gerrym51, go_cubbies22, grandmadonald, grhodes50, Happy Vibe, herk7769, hjgrimm1, Hob, jacksum2, jamiller45, jdefeo1, JDWeir, Jo54, johnthecamper, Joseph5410, kathomas, keep camping, kegoneill, LauraW, LChance, leanne, LeNe4847, Loui, Mattpopp, mcbride5, merlin66043, mhartzel, MilCop4523, ng2951, Painless, pchrcane65, Poppy Bill, PrairieBoy, realebill, ret2006, RJHuser, rkswyo, rschoono289, Rugged Brown, sabre5er, Sailfish Bret, Scriggs1, scroses40, SDENN4281, Sg6923, Shasta1, Shawomet3, sideout1961, simon, skipper194242, stevem4134, tedstr, texwolves, Triguy, T_LMurphy, UPGRADER, VTX Al, Wilkrich, william.migues, Zama |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
