Old 07-08-2016, 09:23 PM   #11
Originally Posted by RamblerGuy View Post
Guys with 5 star tunes,
If you reprogram the PCM to stock, take it to Ford so they can reprogram it for new emission tuning, then you reprogram it with your 5 star, won't you wipe out the changes that Ford just made? What's the point of taking it to Ford?
x2, unless it is just to pass inspection, then return to good settings.
AbdRahim is offline   Reply With Quote
Old 07-10-2016, 06:58 PM   #12
RedLdr1's Avatar
Any time you visit a Ford dealer they should be looking for any open Recalls and TSB's on your chassis. If you don't do the Recall, and later visit a dealer, they could load the new OEM tune while you are in the shop without even asking you. And that would delete your 5 Star tune... It's safer to let them do the Recall when you want it done, and then reload your tune, rather than to chance it later....
Wayne and Christine
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium
RedLdr1 is offline   Reply With Quote
Old 07-12-2016, 05:15 AM   #13
That makes sense. I've never taken our E450 to the dealer. We've not needed any warranty repair. I'll call them and find out if there are any bulletins that I need to know about.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 07-12-2016, 06:23 AM   #14
If you have a 5 star tune and your vehicle has to go for emissions (smog) testing, you may have to return the vehicle to stock and drive it for a while before getting the test done. I had the 5 star on a f350 with the 6.8 and it failed with the tune on. I believe the tune does not run all of the required emissions reporting that the stock tune does. After returning the it to stock and driving it for a day it passed.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
factory, recall
