Old 03-29-2018, 02:21 PM   #1
E450 Torque Specs - Sway Bars
Does anybody have the torque specs for a newer E450 w/ regards to the front and rear sway bars?
Hellwig has simple bolt on instructions but the sheets refer to 'Ford Specs' as far as torquing the bolts back down. Not very helpful - reaching out directly to Hellwig resulted in response advising I contact Ford. I'm sure Ford isn't going to touch a aftermarket part install w/ a 10' pole ....
So has anybody replaced the front and rear bars w/ a Hellwig product?
Roadmaster has torque specs on their product, but I can't be positive the bolts are the same. The Roadmaster also costs significantly more then Hellwig and requires I drill for the rear sway hangar bar install. I don't want to drill anything.
Anybody have the torque specs?
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 03-30-2018, 09:14 AM   #2
SeaDog's Avatar
They said refer to ford specs, just ask ford what the stock sway bar bolts are torqued to you don't need to tell them you are installing an aftermarket and torque Hellwig to that spec
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-30-2018, 09:57 PM   #3
The perfect torque for any bolt- tighten it till it breaks and back up half a turn
mercury9 is offline   Reply With Quote
Old 06-29-2018, 11:26 AM   #4
Previous Member
Who would post such a Stupid Answer
You should not be on this Site.
Sent from my SM-T560NU using Forest River Forums mobile app
allan kay is offline   Reply With Quote
Old 06-29-2018, 11:37 AM   #5
DieselDrax's Avatar
Their post was clearly sarcastic and was posted over 3 months ago. Please relax, your post didn't contribute anything of value either.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is online now   Reply With Quote
Old 12-13-2018, 04:51 PM   #6
Chief tinkerer
Gidyupgo's Avatar
S1njin, I put the BlueOx rear sway and trac bar on. It came with a torque sheet.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
sway
