03-30-2015, 10:11 AM
Effective Use of Lower Gears While Climbing
We have a gas motorhome.
While driving to Salt Lake City yesterday, we fared well on all but one of the climbs. On that one, it occurred to me that I should have used a lower gear (after D, we have 3, 2, and 1 on the column).
Then it occurred to me that I've never driven an automatic transmission and dropped to a lower gear while climbing!!
What's the proper technique? Do I just put it in the gear while still driving? Should I go all the way to 1 from the get-go....or start with 3?
Thanks for your guidance.
Christian
Reno, NV
2015 Georgetown 270
Days Camped 2015: 40
Days Camped 2016: 03
03-30-2015, 10:16 AM
If you have the throttle on the floor, it will downshift automatically.
03-30-2015, 10:28 AM
The beauty of an automatic trans is that it will select the correct gear for operation under normal driving conditions. If you are climbing a hill the trans will gear down when needed by its self, leave it in " D " and keep your foot pressing throttle peddle.Don't start pulling shifter back into other gears until you have more experience driving a automatic. Then you can start using 3,2,1 for helping slow down on hill decent and pulling away in mud or snow.Read your chassis manual for more info.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
03-30-2015, 10:38 AM
In D, the top gear is almost always an overdrive gear. Stay away from an overdrive gear.
You don't say what your TV is, so.....
Here's what I do. I have a Nissan Armada 5.6l with the 5sp auto and tow package. I tow in tow mode (button on the dash) and put it on 4. Very often, 4 is too tall a gear on the highway, and I switch to 3. In three, the engine is making a ton of noise, 3000rpm or so, but don't worry. Engines are designed to run at these rpms for LONG time periods. By putting it in 3, I'm avoiding lugging (my 5.6l is not a diesel, and thus <2000 rpm is not very effective), and I'm keeping the torque converter locked up (saving energy and keeping the tranny cool).
YMMV
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
03-30-2015, 10:41 AM
If I feel the trasmission hunt, shift back and forth a lot, between D and 3, I just go for 3. Like strong winds or a grade with rolling flats ect...If I feel the grade is steep enough where it will eventually pull me down to 45 mph, I will just lift and go to 2. Then I can just give the throttle I want without being pedal to the metal all the time. The higher engine speeds give better cooling for engine and tranny. 45 is the limit on 2 and 25mph on 1 generally, for climbing or engine braking.
03-30-2015, 10:42 AM
YMMV
He's driving a motorhome not towing
2014 Forester 3051s
2012 Sonic toad
03-30-2015, 10:50 AM
Take The Road Less Travld
I which case, stay in D. the motorhome knows what to do.
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
03-30-2015, 10:58 AM
Whoooops.....please ignore my post. I should read more carefully.
03-30-2015, 12:21 PM
Not sure that I agree with that. Much better to manually downshift prior to slowing down to much going uphill than adding continual more pressure on the gas pedal to get the auto. to downshift for you.
Going downhill you need to put it into tow/haul or manually downshift to save your brakes.
These are somewhat more advanced driving skills than what you need for a car.
Google the subject and I'm sure you will get some good information.
03-30-2015, 12:24 PM
With experience, you will "feel" when the transmission needs to go down a gear. Many of us anticipate this when approaching a hill, and downshift from D to 3 at the bottom of the hill. If you are going slow and climbing, you will likely be in 2 or even 1.
Also, don't forget to build up some speed when going down one hill and approaching the next hill. Your momentum will help you up the hill.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
03-30-2015, 08:05 PM
I have a button on the steering wheel and I put shifter in M not D and shift manually not allowing it to slow down before it shifts on hills...2014 Chevy 4500..
gtony2
03-30-2015, 08:21 PM
If you are not happy with the shift pattern I suggest that you look into a 5 Star tune. It will make an amazing improvement in drivability and hill climbing for the Ford F53 V10! Custom Dynomemeter Chassis Tuning Products and Services - 5 Star Tuning
LLVanB
2013 Coachmen Encounter 36KS, 2020 Chevrolet Equinox toad, Roadmaster Falcon 2, Brake Buddy Vantage Select, Protect-a-Tow, 5 Star Tune, M4 LED lights, BIRD, ATS, Xantrex PROwatt 1000 SW Inverter and many other accessories & mods.
03-30-2015, 08:43 PM
Forgot all about using the manual as a resource for this!!! I did check it out, and it helped a great deal.
Thanks for the tips!
Originally Posted by LLVanB
I'll check it out. Thank you for the link.
Thanks to everyone for their input. I feel better about it already.
Christian
Reno, NV
2015 Georgetown 270
03-30-2015, 09:05 PM
I always used the idea that whatever gear I went up the hill, to use the same gear going down the hill. I.e. needed 3rd to go up, then 3rd to come back down. Has worked well for me for several thousand miles. Especially in the Appalachian mountains.
