Old 06-15-2019, 04:20 AM   #1
Senior Gold Member
rthomaslyons's Avatar
Engine or Fuel Additives for Triton V-10
Does anyone use any engine or fuel additives on their Triton V-10 equipt motorhomes. When I was towing a TT with my Ram Cummins I used to add fuel condition and upper cylinder lube sometimes to the fuel.
rthomaslyons
2019 Sunseeker 3010 DSF
rthomaslyons is offline   Reply With Quote
Old 06-15-2019, 05:27 AM   #2
Dodge Guy's Avatar
The V-10 doesn’t need any additive. You can just run 87 octane, although I find that running 89 it runs much better!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-25-2019, 09:31 PM   #3
My V-10 is stored for 7 months during our cold winters. Each fall I add 4 or 5 cans of Seafoam to the filled 55 gallon fuel tank as a stabilizer. In the Spring, I try to use all that fuel before adding any. There are no problems, and it runs like a clock.
eddard is offline   Reply With Quote
fuel
