Old 07-27-2014, 10:52 PM   #1
Engine stumbling
We have just purchased a 2004 Lexington 255. It has a stumble which the dealership did not find. We drove it from Florida to NJ. The stumble at low speed got worse. My initial thought was injectors plugged, so I used techron injector cleaner with no results. Any ideas? The vehicle has 52000 miles on it.
Nhisday is offline   Reply With Quote
Old 07-28-2014, 04:38 PM   #2
tmhyer's Avatar
Are there any trouble codes? My 2014 Ford V10 is not a smooth revving engine. Is that what you have?
tmhyer is offline   Reply With Quote
Old 07-28-2014, 06:25 PM   #3
Retired Ford Tech
Is or did the check engine light come on. It is probably an ignition coil. The trouble code will start with PO3 with the number 1 thru 10 depending on if it's a V-8 or V-10. If the light came on, but not now, the PCM will store the code. The PO code I mentioned is for a cylinder misfire. Some Auto Parts stores or repair shops will scan the PCM for free. If it's not a misfire, let me know what other codes you retrieve. Have fun Rod
rvpezzano is offline   Reply With Quote
Old 08-02-2014, 11:24 PM   #4
ernest917's Avatar
Plugged fuel filter????
ernest917 is offline   Reply With Quote
Old 08-14-2014, 03:30 PM   #5
kenandterry's Avatar
From what I'm reading, it sounds like this problem is clearly with the performance of the Ford engine, and nothing from Forest River.
Your original posting mentioned you had been to a dealership, but I'm not sure what type.
My suggestion would be that you take it to an authorized Ford dealership. The engine compartment and working of the motor are not foreign to them and they would be the people to see for getting your trouble resolved.
IMHO
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-14-2014, 03:41 PM   #6
sammonilla's Avatar
Sounds like a fuel pressure or delivery issue. ALso could be coils but you should have mis-fire codes with a flashing SES light is that was the case.
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 08-14-2014, 04:26 PM   #7
TURBS's Avatar
Fuel filter issue?
TURBS
"SABRE OWNERS UNITED"
Old 08-14-2014, 09:19 PM   #8
Fuel filter should affect it more with heavy loads when need higher fuel flow not low speed.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 08-14-2014, 09:35 PM   #9
Recent problem on Georgetown 374...turned out to be bad coil which also compromised one spark plug....replaced both items...perfect!
ynott96 is offline   Reply With Quote
Old 08-14-2014, 09:40 PM   #10
We often find moisture in the holes causing stumbling and missfires that are not serious enough to cause the SES or CEL to light. I did 8 plugs and coils in a 2006 5.4 and 8 plugs and coils in a 2004 4.6 last sunday for this exact issue. the 4.6 did pull a stored code but not the 5.4
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
