Old 03-05-2019, 10:01 PM   #1
360true's Avatar
Ford Introduces New F-53 V8 Engine, Transmission*(3/5/2019)
Story by*Rick Kessler
While Ford Motor Co. is adding greater connectivity and new smart driver-assist technology across its commercial vehicle lineup — including the Transit, Super Duty chassis cab, medium-duty trucks, E-Series, and F-53 and F-59 strip chassis — perhaps the biggest change is the introduction of the all-new 7.3-liter V8 engine paired with an all-new 10-speed TorqShift automatic transmission.
[https://www]New Ford F-53 chassis
The 7.3-liter engine and 10-speed transmission combo replaces the 6.8-liter V10 with six-speed transmission, a setup that had been around for the better part of two decades. While exact performance specs will be released along with the 2020 models later this year, officials confirmed the 7.3-liter V8 would generate*more torque and power*than the outgoing engine, which offered 320 horsepower and 460 lb.-ft. of torque.
Although Ford debuted its new model commercial vehicles March 5 at The Work Truck Show in Indianapolis, RVBUSINESS.com was granted early access in January. In addition to the debut of the all-new F-600 Super Duty chassis cab, the new 7.3 V8 and 10-speed transmission certainly garnered the most attention, especially given its importance on the F-53 chassis — a platform that boasts more than 90% of the North American market in terms of gas-powered Class A motorhomes.*
While the F-53 also gets a new steering column, instrument cluster, electrical architecture, and upgraded center of gravity capability on higher GVWR models, the new engine and transmission represent a significant milestone in that platform’s evolution.
Joel Beltramo, Ford’s engineering manager overseeing development of the 7.3-liter engine, told RVBUSINESS.com the new power plant will “deliver high performance in a compact package, providing durability, ease of maintenance, and the towing and payload capability customers want.”*
“This will offer a step up both in performance and fuel economy,” he continued. “And when you look at durability, because it's built for the medium duty business it’s going to run and run and run with very low and simplified maintenance.”
Beltramo pointed out the engine’s lower profile due to its in-block cam that reduces engine height and width. The result is a smaller “doghouse” compartment in the cockpit, he added, which results in a little more comfort and convenience for RVers.
Its compact package also provides greater maintenance access for technicians, Beltramo noted, and because it has two fewer cylinders it also uses fewer parts than the outgoing V10, resulting in less downtime at the shop and lower long-term ownership costs.*
In addition, the 7.3-liter uses an all-new cam-in-block, overhead-valve architecture with cast iron block and forged steel crankshaft for maximum durability. Port injection with variable-valve timing optimizes the intake and exhaust to match performance with workload. Oil jets cool the pistons under heavy loads.
As for the 10-speed TorqShift automatic transmission, it features a wider gear ratio span than the 6-speed and is designed for the harshest towing conditions. The heavy-duty transmission continues to offer class-exclusive live-drive power takeoff, which allows the operator to engage industrial equipment and accessories, such as snowplows, with the truck in motion.
The electronically controlled transmission has selectable drive modes that include normal, tow/haul, eco, slippery, and deep sand and snow. Worth noting is that — even with four extra gears — the entire unit is engineered to fit in the same space as the outgoing 6-speed and yet weighs only 3.5 pounds more.
Other upgrades to the F-53 strip chassis include smart new driver-assist technologies such as automatic emergency braking as well as additional optional elements of Ford Co-Pilot360 technologies, which encompass adaptive cruise control, electronic stability control, lane departure warning, Driver Alert System and auto high-beam headlamps.*
“In general we’re just trying to improve the overall drivability,” Beltramo said. “Fundamentally, if you think about merging on the freeways and accelerating, this will bring a more comfortable experience. It just moves the performance of the vehicle a bit closer to a car in terms of its ability to manage in traffic.
“If you think the gasoline RVs, people want the RV experience, but they're also trying to not move dramatically away from the vehicles they're used to driving day to day. So, any features we can bring that bridge the gap to the functionality of the cars — the driving experience, the safety devices — that just makes the (recreational) vehicles more friendly for somebody's who's not driving it every day,” he continued.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 04-07-2019, 10:34 AM   #2
On the road again...
Thanks for the information
Thanks for posting this story. I have a 2015 Encounter on a F53 and I wish it had a little more power and the 10 speed trans. Actually, I wish it had the 6.7 diesel and a 10 speed, I would be a happy camper. I would just take out my hearing aids.
2015 Coachmen Encounter
2001 CRV Toad
Let's go campin'!
MMMH is offline   Reply With Quote
Old 04-08-2019, 01:13 PM   #3
Dodge Guy's Avatar
Personally I would love to see them do something with the rideablity side of it! I think it’s long overdue for an air ride option. Maybe even an independent front suspension update. Surely they can get this ancient chassis to ride better than an 1800’s lumber wagon!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
ford
