Old 07-07-2016, 06:53 PM   #1
Generac 4700-0 Overheats!
I have classic symptoms- Overheats with load at 100F or higher. I have measured the oil temp sensor with IR gun, shut-off switch fires at exactly 300F, which agrees with sensor rating.
I agree with conclusion before, THE EXHAUST IS TOO CLOSE TO OIL SENSOR! The amount of radiant heat from exhaust is huge. I am thinking that a heat shield needs to exist between exhaust and oil filter/sensor.
BTW, there is a lot of air flow internally, but the air movement near the exhaust /oil filter/ carburetor is minimal. Not sure why- I would expect this to be highest air flow, not lowest. Perhaps there is a problem with internal air seal or clog in intake grate? In any case, the air flow out is good and heat is coming out.
Steven010 is offline   Reply With Quote
Old 07-08-2016, 11:27 AM   #2
Head Rambler
Have you thought about trying a piece of the heat shield tape like you find at auto parts stores between the exhaust and sensor?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
