Old 12-08-2019, 03:36 PM   #1
Generator Switch
Where in the heck is the switch to turn on the generator? 2011 Greogetown 337DS.
KheSanhMike is offline   Reply With Quote
Old 12-08-2019, 04:05 PM   #2
bubbles's Avatar
The gen switch should be one of these switches.
Old 12-08-2019, 08:56 PM   #3
Dodge Guy's Avatar
It's the one that is lit up.
There is also one on the generator behind the panel.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 12-08-2019, 09:07 PM   #4
PPST Wannabe
kenandterry's Avatar
Look for the switch that has the lightning bolt pattern.
Push the top to start.......push the bottom to stop.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 12-09-2019, 07:34 AM   #5
bubbles's Avatar
It's a 2011 337ds so the switch may not be the one shown, also to start the gen press the bottom of the switch till it illuminates (indicating primed) then press the top to start.
Old 12-09-2019, 09:06 AM   #6
Lacey's Spring, AL
formerFR's Avatar
or the switch on the GENERATOR itself....
also, if you have an AGS(auto Generator starter) as part of your Inverter's control panel, it will also have a 'TEST' setting that will start the generator, run it for 30 seconds, and then shut if off, to test the working of the AGS..... : )
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
generator, switch
