Old 04-29-2016, 03:35 PM   #1
Georgetown water leak into ceiling and out from AC
Can anyone out there describe how water either from blowing rain or AC condensation causes water to get into a motor home's ceiling and to leak from around an AC?
hikerjohn7 is offline   Reply With Quote
Old 05-18-2016, 12:34 PM   #2
The first thing to check is the sealant around your AC unit if ok check the hole roof for missing or loose sealent, Good Luck��
JW DUKE is offline   Reply With Quote
Old 05-18-2016, 01:36 PM   #3
If your AC freezes up, the ice will melt from the fins and drip into the RV, if that is the case run your AC on Hi all the time and should not freeze.
The AC is attached to the RV with a 1 inch soft rubber gasket, if it was not tightened correctly the gasket can leak.
And of course water can get in from anywhere, make sure all seams on the roof are sealed.
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 05-28-2016, 05:27 PM   #4
In Florida it's hot and ac continually runs. I had water dripping from ac on to bed and the floor in a different area. I was told that the weep holes on the roof probably were blocked with leaves ect preventing drainage and found its way into coach. Told to get on roof remove ac cover and clear the weep/drain holes----problem solved. Also told while in Florida's heat run the a/c fans on high setting So far so good
360 Georgetown XL 2015
twoclaws is offline   Reply With Quote
georgetown, leak, water, water leak
