Old 10-30-2017, 05:29 PM   #1
Georgetown wheel well size
Has anyone replaced the stock 19.5 wheels and tires with the larger 22's? Did the swap require the wheel wells to be modified?
campingtom is offline   Reply With Quote
Old 10-31-2017, 04:48 AM   #2
Without knowing your rig, I would not think that a 1-1/2" larger diameter would be a problem unless the tire will bottom out against the wheel well. Otherwise it will also change the height of your trailer, if you have a trailer, and it might mess up the alignment with your hitch ... or your speedometer if you have the style that you drive.
JCDMeyer is offline   Reply With Quote
Old 10-31-2017, 04:51 AM   #3
* 2-1/2 inches. 1-1/4" radius
georgetown, wheel
