Old 06-14-2018, 06:52 AM   #1
Good drinking water
You wouldnít think it would be so hard to find a good solution for decent drinking water, but Iíve been trying different things for awhile and still not satisfied. We do have a distiller, which makes probably one of the best tasting, but in myrtle Beach heat we try not to do anything that takes away from the air conditioning and the distiller makes a lot of heat! I put a filter on the faucet and that is good for some places, but down at the shore it seems to really not help too much. Iíve considered a reverse osmosis like we have at our house, but with using a lot of water and all the hook ups I donít think I want to do that either. I just looked at the zero water filter system, which sounds really good and gets some great reviews, then I start reading all the bad ones and then keep looking.
If we were full timers Iíd go the RO route, but most trips are long weekends with our biggest trip to Myrtle Beach coming up, which will be 10 days and thatís where the water is the biggest problem for us. My wife is definitely pickier about the water taste than I am, but I do want to find something that sheís happy with. Any suggestions appreciated if youíve found something youíve been happy with. We do have the house filter for our 3010, but thatís not really good enough for drinking water to us. We drink a lot of water and do get individual bottles for the beach, but Iím talking for coffee and drinking around the camper. We probably use close to 5 gallons a day.Thanks in advance!
carol108 is offline   Reply With Quote
Old 06-14-2018, 07:00 AM   #2
jd50i's Avatar
You can get distilled water just about anywhere for about $1 a gallon or less. I use it servicing batteries just remember any minerals needed by your body have been removed from distilled water.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is online now   Reply With Quote
Old 06-14-2018, 07:09 AM   #3
Thanks for the reply. We usually only do the distilled when weíre camping so the mineral thing isnít a concern for us there. We really didnít want to do the gallon jug thing since we use so much, but thatís always a possibility.
Old 06-14-2018, 07:23 AM   #4
Kaadk's Avatar
Some people will pick up a 2 or 3 stage 'whole house' filter like this:
https://www.homedepot.ca/en/home/p.w...001103077.html
and then adapt it to hose fittings so they can use it outside the rig on the incoming city water connection.
I never needed to before, because our water has generally been clean enough for the onboard filter in our Flagstaff to handle. But the new Surveyor doesn't have an onboard, and the little blue Camco ones don't seem to do as good a job so I've been considering going this way.
Old 06-14-2018, 07:27 AM   #5
jeff64's Avatar
I have been pretty diligent with sanitizing and flushing the tank and lines a couple time a season. Every drop that goes through the TT whether from the city connection, potable tank or jerry cans goes through the whole house filter with the taste, odor sediment charcoal 10 micron filter. We carry a case of bottled water for a few in the fridge. I dump everything on the way out of the CGs if it's going to be more than two weeks sitting. Any more thought into this would drive me nuts. I ain't dead yet!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
jeff64 is online now   Reply With Quote
Old 06-14-2018, 07:28 AM   #6
Dr-G's Avatar
I have a Brita pitcher and the water is good enough for us. Some places are definitely worse than others. Zero water supposedly a good choice also. Not sure if they have a carbon filter in there also.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Equilizer WDH
Goodyear Endurance Tires
Dr-G is offline   Reply With Quote
Old 06-14-2018, 07:30 AM   #7
Fulltime family RVer
Get a Berkey Water Filter. We enjoy clean water no matter where we are. We prefer it to bottled water.
It just takes up a little bit of counter or floor space (if you get the stand). No heat as it’s a gravity filter.
Old 06-14-2018, 07:34 AM   #8
Flybob's Avatar
Reverse Osmosis will work, but there are a few downsides.
1. How do you plan to handle the waste water. Usually a good RO system will product 2-3gals of waste water for each gallon of good water.
2. Using it on a water system that has chlorine in the water can damage many of them.
3. Will take up space as you need space for system and a storage tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-14-2018, 12:45 PM   #9
Thatís exactly why I was looking for something other than RO.
Old 06-14-2018, 12:56 PM   #10
Old 06-14-2018, 03:56 PM   #11
Just as confused as you
Scrapper's Avatar
The best water I ever tasted came straight out of the ground from an artisan well out in the middle of a field. There was a cup hanging on a fence post for anyone who wanted a drink. Was so cold you would get brain freeze if you drank it too fast. My parents also had an artisan well in their back yard which the pump drew from.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 06-14-2018, 04:20 PM   #12
We buy gallon bottles of water... mineral or distilled. Not an ideal solution, but at least we like the taste.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 06-15-2018, 08:41 AM   #13
Walmart has great water for 37 cents per gallon. I've had two 3 gallon bottles for drinking and cooking for 9 years. Walmart has 5 gallon bottles, they'll last forever too!! Cases of bottled water are not only expensive, they're anti ecological. Buy a couple tumblers to keep in the fridge for cold drinking water.
Schvarak is offline   Reply With Quote
Old 06-15-2018, 09:10 AM   #14
rebeltown's Avatar
Distilled water is something you put in your battery or radiator, not drink! It has no minerals so NO taste at all. It will also remove healthy minerals in your body as it passes through your system. Everything in this universe likes equilibrium.
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 06-15-2018, 09:32 AM   #15
I fill my FW tank using a filter and drink what comes out of the faucets.
johnbryanpeters is offline   Reply With Quote
Old 06-15-2018, 09:48 AM   #16
lswartz's Avatar
You might consider 2- 3 water containers from home. Just donít skimp drinking in that heat.
2013 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 06-15-2018, 10:09 AM   #17
At home we use the Kube system and really like it. It attaches to the cold water inlet under our kitchen sink and comes through our regular kitchen faucet. I don't know anything about your RV, but if we had the space for it in our Mini Lite 2304ks, we'd definitely put one in. The filters last a really long time.
http://www.kubewater.com/discover/
wannabeowner is offline   Reply With Quote
Old 06-15-2018, 10:09 AM   #18
I tried that once. If your water at home is perfect, that'll work for one fill! Also CG water is notorious for having trouble with their water. Not good to put in your mouth. Disgusting!!!
Old 06-15-2018, 10:36 AM   #19
That's the same with RO systems. You need to add vitamins and minerals back to the water.
Old 06-15-2018, 11:35 AM   #20
BWT Premium Water Filter Pitcher & 3 Filters, Award Winning Austrian Quality, Technology For Superior Filtration & Taste https://www.amazon.com/dp/B01BFNHU4E..._uY9iBbB5Y05FY
Thanks for the responses. We were going to go with the zero water, then I saw this and weíll give it a try. They all have great reviews and some really bad ones. Iím sure my wife will have me pack the distiller in case this doesnít work well.
water
