Old 09-19-2015, 02:52 PM   #1
Vince and Charlette's Avatar
Grease wheel bearings yearly - Really???
TT and 5th wheel forums are filled with advice affirming the need to grease wheel bearings. But, since Class A's are a whole different breed, and since greasing the wheel bearings looks to be $250-$500, and since this is not a DIY project, and since it's supposed to be done yearly according to the generic MH owner's manual, it seems odd that the manufacturer would expect to owners to regularly spend this much on one maintenance item. So, why would FR stipulate yearly re-greasing? If it's that critical (which it is) why re-grease the old ones? Shouldn't they have said "replace" bearings yearly? Thoughts?
PS - if I'm going to pay this much, what else should I pay to have done to the chassis?
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 09-19-2015, 03:18 PM   #2
Ford Idaho's Avatar
I would refer to the chassis manufactures site, I would think every 75,000- 100,000 miles would be more accurate.
Old 09-22-2015, 03:32 PM   #3
trdutch's Avatar
I own Two little utility trailers and I do my wheel bearings every year
I think they are talking about Trailers in general
Them little wheels are spinning away back there
Your motorhome wheels are like you car or truck
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 09-28-2015, 09:17 PM   #4
Dabmeb's Avatar
If it's available based on the chassis switch to oil filled hubs and synthetic gear lube or semi fluid synthetic grease
Dabmeb is offline   Reply With Quote
Old 09-28-2015, 09:44 PM   #5
Oaklevel's Avatar
I would go by the chassis manual for a MH but there is no need to grease / pack trailer bearings annually unless they are pulled many many miles annually....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 09-29-2015, 12:55 AM   #6
2007 WildCat 32QBBS
05CrewDually's Avatar
Convert to wet hubs and service is as easy as removing a drain plug and then refilling with fresh gear oil through a rubber plug in the center. As long as the oil is clean and has no shiny metallic to it your bearings are good.
Stemco is the manufacturer.
05CrewDually is offline   Reply With Quote
bearings, wheel
