what ground are you connecting and disconnecting? If you are disconnecting the main ground to the camper be very careful as you probably have a hot skin condition when it is disconnected.
Have you tried it with all the breakers in the panel off?
Do you have a voltmeter? If so with AC power disconnected and all breakers off set the meter to the lowest resistance range and measure between ground and common and between ground and the hot side.
Please add detailed photos of the power panel, especially showing the ground and common bus bars
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
