Old 03-14-2009, 09:31 PM   #1
mlg
help
Hi there , I looking for some help with a 2001 24 class c forest river sunseeker
My dad past away and left me his motorhome. I was hoping someone could
tell me where the fresh water tank drain valve is located . I've looked for
hours and I can't seem to find it . Any help would be greatly appreciated
thanks (no owner manual)
mlg is offline   Reply With Quote
Old 03-30-2009, 06:52 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
I'm not sure if the Sunseeker has it in the same place but ours is in the compartment where the propane tank is. It will have a valve and cap on it. You may want to call a Sunseeker Dealership and ask them for the location.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-30-2009, 08:44 AM   #3
shorty's Avatar
I used to have a 2900 Sun Seeker and the tank drain valve was located on the passenger side behind the rear wheels. It looks like two long plastic tubes coming down with white caps on the ends.
Shorty
2008 Georgetown 373DS
shorty is offline   Reply With Quote
Old 10-09-2009, 01:15 PM   #4
Well, I have had documenting everything. The user manual is rather generic and all models appear different (through this forum). I have a 2008 Sunseeker Class C. My fresh water drain valve I found under the rear bed. The bed top frame has to be removed to reach the valve for the fresh water tank and the on/off valve for the water heater. I modified the storage compartment so I could access the valves and the water filter from there.
On the right rear behind the dual wheels are two clear plastic lines with white caps. I "think" one drains the water heater and the galley lines. There is a third clear plastic tube with a white cap on the left side in the sewage drain compartment that I think drains the lines to the sink and shower.
I am learning through experience too.
countryboy is offline   Reply With Quote
