Old 04-09-2007, 06:36 PM   #1
Roy
Hot Ceiling Lights
The switch broke on my ceiling light that is mounted on the padded vinyl roof of my 2004 Georgetown motorhome. Upon fixing the light I noticed that the padded vinyl is scorched from the heat of the light. Other lights mounted on the ceiling have also scorched the vinyl. I'm concerned with the possible fire hazard and would welcome any suggestions of ways to protect the padded vinyl ceiling from the excessive heat from the lights.
Thanks, Roy
Roy is offline   Reply With Quote
Old 04-09-2007, 09:32 PM   #2
MrSen's Avatar
You may want to try adding LED lights.......They do not heat up as much as regular bulbs.
MrSen
2007 Ford F150 4X4 Lariat 5.4.
2011 8317RKSS
2006 Rockwood ROO 25rs Sold
Night's camped in 2010 36
MrSen is offline   Reply With Quote
Old 04-10-2007, 08:08 PM   #3
Roy
Thanks for the suggestion. Will check out LED lights.
Roy
Old 04-10-2007, 09:25 PM   #4
LEDs will run cooler, but if you are only going with a bulb replacement, your light output may not be what you are accustomed to.
If you are looking into a total fixture replacement maybe fluorescent lights would serve well?
Here are some options, and I'm sure there are many more:
http://www.go2marine.com/category.do?no=13184
Keep in mind that these suggestion come with limited LED experiences and no 12V fluorescent experience... (only going on what I've heard/read)
'05 Rockwood ROO 25RS
mn_308 is offline   Reply With Quote
Old 04-11-2007, 09:42 PM   #5
Roy
Thanks...
A good selection on the link you provided. I had florescent lights in my previous "classic" Revcon motorhomes and the lights definitely were cooler.
Perhaps for "piece of mind" I will need to do a replacement rather than trying to keep the excessive heat away from the padded ceiling.
Roy
