Old 11-26-2015, 11:49 AM   #11
onetonford's Avatar
here is the pdf I found.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 11-26-2015, 11:50 AM   #12
Tom48's Avatar
Originally Posted by A32Deuce View Post
I thought Carbon monoxide and propane were connected straight to house bat. The one in my rv was when I replaced it.
I think some chemical sensors have only a seven or ten year life and the unit has to be replaced, but maybe that is just the residential detectors?
Tom48 is offline   Reply With Quote
Old 11-26-2015, 11:53 AM   #13
A32Deuce's Avatar
I was told RV's are 5 years. Date on the unit.
A32Deuce is online now   Reply With Quote
Old 11-26-2015, 12:29 PM   #14
Can't post the manual from my phone. Will try from my laptop.
Lvnlife1973 is offline   Reply With Quote
Old 11-26-2015, 12:30 PM   #15
Also turns out the installers mounted the bracket where it hid the opening to the batteries. Had to remove the bracket and then it was obvious how to access the battery area.
Old 11-26-2015, 10:15 PM   #16
Some CO and Propane sensor don't have batteries. Mine I had to replace them, no batteries in either of them. You can buy CO sensor that wire in, or wire in and batteries, or just batteries. Propane I have only found the wire in type.
Ditchdigger is offline   Reply With Quote
battery
