Old 11-25-2015, 02:25 PM   #1
How to change batteries on carbon monoxide dectector
Help!! I've searched and even looked at the manual but no instructions on how to remove cover go replace batteries. It keeps beeping!! Help? I know it can't be that hard but I can't figure it out!
Lvnlife1973 is offline   Reply With Quote
Old 11-25-2015, 02:54 PM   #2
bubbles's Avatar
Some have small Philips head screws holding it together. Rub your finger over the back side and see if you can feel indentations through the paper stickers (label etc.). If so, puncture them and deep inside should be the screws. Maybe not your type.
Old 11-25-2015, 02:59 PM   #3
Mine is the Atwood 900-1043...its supposed to have an easy cover removal....apparently not for this idiot!!
Old 11-25-2015, 03:02 PM   #4
wmtire's Avatar
Are you sure it has batteries? I'm not saying it doesn't but my detector doesn't have user replaceable batteries.
Let me see if I can find other posts on it, to tell how to change them.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-25-2015, 03:13 PM   #5
wmtire's Avatar
You are on the right track, as the owners manual in step 4 of page 1 does say that all you do is slide the cover..
http://manuals.heartlandowners.org/m...20Detector.pdf
However, it appears on page 2, that you first remove the detector from it's mounting bracket to get to the battery cover.
Also, this is for an atwood 900-0143, which I am assuming is yours with just a typo...but maybe not.
Old 11-25-2015, 03:19 PM   #6
Darn....nope, mine is the Atwood 900-1043 and it is actually round. There is another PDF out there under Northstar RV? It says you replace the batteries but it doesn't tell you how! We are traveling right now and I'll have more time to look at it once we get to our destination.
Old 11-25-2015, 03:20 PM   #7
Someone complained and said a page was missing out of the manual? I've read it over several times....no help there.
Old 11-25-2015, 03:35 PM   #8
Found page 16!! Did a search for the actual model and found a full PDF. Going to see if it actually works the way they say...you just flip the cover....mmmhmmmm
Old 11-25-2015, 03:40 PM   #9
A32Deuce's Avatar
I thought Carbon monoxide and propane were connected straight to house bat. The one in my rv was when I replaced it.
A32Deuce is offline   Reply With Quote
Old 11-25-2015, 03:42 PM   #10
wmtire's Avatar
Good deal, if you will post the link to that pdf, I may upload it our library here for future.
battery
