Also add screen door closer. Item number 1139. Will close screen and door. We love ours.
So if I put one of these screen door handle/bar on the screen door only I will be able to close BOTH the screen and outer door at the same time. Correct?
Looked it up, looks like a length of Spring that is attached with screws, top and bottom, that you grab and pull ?? But is it attached to the screen door or the big door?
Clarify.......What manufacture is this a part number for?
i installed one of the full handles from camping world on my screen in less than a year i have had to replace the plastic latch on the screen due to breakage. im now back to using the handle on the main door
Camping world..
product appears to be as stated above.
Had to go back to first post and stars reading again, because when posting if a quote isn't used, being we multi-task on here, it's hard to remember all posts. Thanks for responding.
If you are still undecided on what to do I had the same problem but mine started after the dealer repaired my door lock. They installed a new door lock but I couldn't grasp the handle because there was not enough room to grab it. This is what is happening to you if I understand your post correctly. Took it back to the dealer and they replaced it with another handle by a different brand. Lots more room now. I have seen these handle for about 30 bucks. This may be an option as you would have to try something that may not work
