Old 03-23-2015, 10:21 PM   #21
FordHauler's Avatar
Also add screen door closer. Item number 1139. Will close screen and door. We love ours.
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 03-24-2015, 10:33 AM   #22
Frank & Eve's Avatar
So if I put one of these screen door handle/bar on the screen door only I will be able to close BOTH the screen and outer door at the same time. Correct?
Frank & Eve is offline   Reply With Quote
Old 03-24-2015, 10:54 AM   #23
Left Coast
What's this 1139 ? Who's number?
Old 03-24-2015, 11:12 AM   #24
Looked it up, looks like a length of Spring that is attached with screws, top and bottom, that you grab and pull ?? But is it attached to the screen door or the big door?
Old 03-24-2015, 11:26 AM   #25
Left Coast
Clarify.......What manufacture is this a part number for?
Old 03-24-2015, 11:32 AM   #26
Camping world..
product appears to be as stated above.
Old 03-24-2015, 12:17 PM   #27
i installed one of the full handles from camping world on my screen in less than a year i have had to replace the plastic latch on the screen due to breakage. im now back to using the handle on the main door
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
https://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 03-24-2015, 03:03 PM   #28
Left Coast
Camping world..
Had to go back to first post and stars reading again, because when posting if a quote isn't used, being we multi-task on here, it's hard to remember all posts. Thanks for responding.
Old 03-27-2015, 06:46 PM   #29
If you are still undecided on what to do I had the same problem but mine started after the dealer repaired my door lock. They installed a new door lock but I couldn't grasp the handle because there was not enough room to grab it. This is what is happening to you if I understand your post correctly. Took it back to the dealer and they replaced it with another handle by a different brand. Lots more room now. I have seen these handle for about 30 bucks. This may be an option as you would have to try something that may not work
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 04-10-2015, 07:36 PM   #30
This is our solution to easily pulling the door closed. A $2.97 fix. Think it will work.
cat, door, modifications
