Old 03-23-2015, 08:06 AM   #1
Frank & Eve's Avatar
Inside door pull modifications ?
I am needing to do something about how to pull the door closed once inside the coach. The pull that is on mine you have to use your finger tips to close it. This is difficult for me. Have thought about drilling holes in the existing pull handle and put a regular pull handle, like for drawers on it. Also thought about attaching a strap with a bolt and nut just to be able to grab and pull. Any thoughts? Surly I'm not the only one that has a problem with closing the door!
Frank & Eve is offline   Reply With Quote
Old 03-23-2015, 08:26 AM   #2
Got my handle off Amazon. Under $14. Goes across door, 4 screws. Do a search
Maybe someone here can post up a link as I don't have it.
grumpyer is offline   Reply With Quote
Old 03-23-2015, 08:48 AM   #3
TURBS's Avatar
I just used this . 1.99 any hardware store.
Old 03-23-2015, 08:54 AM   #4
BiigDaddy's Avatar
I have this one and it is a solid product.
http://www.campingworld.com/shopping...k-handle/35872
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 03-23-2015, 11:52 AM   #5
Tanddhall's Avatar
I used what BiigDaddy listed from Camping World on both my doors and would not use anything but them ever again. So easy to grab and shut even with full hands.
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 03-23-2015, 12:25 PM   #6
I guess I'm not getting what Ya'll are talking about. I looked at what BigDaddy suggested. I'm I understanding that you put this screen door bar on the heavy door as well as the screen? I'm not talking about closing the screen but the outside door. Or will that screen door handle close both doors...
Old 03-23-2015, 01:02 PM   #7
Evereddie's Avatar
I was just about to post the same question. Sounds like your door is the same as mine and the 'big door' attaches to the screen door with a weak plastic latch. I put the big handle on the screen door just like big daddy and after using it to close the doors when latched together the plastic latch broke in 2 weeks. I saw that weakness and already bought a backup latch just in case. They make a metal latch but it doesn't quite fit our application. We don't use the big handle when doors are hooked together..
Evereddie is offline   Reply With Quote
Old 03-23-2015, 02:00 PM   #8
Left Coast
Is it a problem to open slider in screen door and use outer door handle ? I thought most units had a good handle on them to close the door. Old,worked to hard hands here also.
Old 03-23-2015, 02:26 PM   #9
Witch Doctor's Avatar
I like the full handle that CW sells, But the only problem is that once installed and the screen door is close on a 8269WS you can only open the pantry door 3/4 open without hitting the bar. Should have just used what Turbs showed...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-23-2015, 02:28 PM   #10
TURBS's Avatar
I think bombdoc did the same to his after he seen mine.
Simple cheap and takes 30 seconds to install.
cat, door, modifications
