Originally Posted by rattleNsmoke
I see the difference. Thanks for the link. How are you gonna mount the side mount? Drill thru the cab for the coax, and a self adhesive on the plate? By the product description and review you should be good to go. The only thing I don't like is that you can't shorten the antenna, only add to it to decrease the SWR's.
Yes it looks as if I would have to mount it infront of and above drivers or passengers window. It probably will be inside one of the cabinets and you have to remove the inner wall all the way out to the fiberglass.
That is the one thing I dread doing and that is why I'm still pondering the loaction. I can mount it lower in front near the engine but that may be bad for signal being low.
So that is why I'm here asking and see where others have mounted their antennas.
