Old 11-10-2012, 09:49 PM   #1
Iggy's Avatar
Installing CB Radio Antenna NGP
I'm considering installing my CB radio inmy MH and know most use Non-Ground Plane antennas.
I'm considering buying a Firestic LG4M2 which is the 4ft black Firestic with side mount.
Has anyone installed this antenna or have any thoughts on Non-Ground Plane antennas in motorhomes?
Old 11-10-2012, 10:12 PM   #2
rattleNsmoke's Avatar
Would it be any different than an antenna mounted on a pickup truck? I've had antenna's with center and base loads mounted on the roof and mirrors. Firestick is a great brand altho I'm currently using a K40. I don't foresee any issues.
rattleNsmoke is offline   Reply With Quote
Old 11-10-2012, 10:22 PM   #3
Iggy's Avatar
I also use a K40 on my pickup but when you have a motorhome made of fiberglass and very little metal above it is difficult to get any reflection with signals in and out. So they came up with the No Ground Plane (NGP) antenna system that has a tuned coax with resistance built into the coax to fake the entenna out and it will reflect using the coax instead of a metal structure. Most motorhomes as well as the newer fiberglass big rig truck use them.
Here is a link to the antenna system
LINK
Old 11-11-2012, 07:22 AM   #4
I see the difference. Thanks for the link. How are you gonna mount the side mount? Drill thru the cab for the coax, and a self adhesive on the plate? By the product description and review you should be good to go. The only thing I don't like is that you can't shorten the antenna, only add to it to decrease the SWR's.
Old 11-11-2012, 09:14 AM   #5
Iggy's Avatar
Yes it looks as if I would have to mount it infront of and above drivers or passengers window. It probably will be inside one of the cabinets and you have to remove the inner wall all the way out to the fiberglass.
That is the one thing I dread doing and that is why I'm still pondering the loaction. I can mount it lower in front near the engine but that may be bad for signal being low.
So that is why I'm here asking and see where others have mounted their antennas.
Old 11-23-2012, 07:09 PM   #6
Newellri's Avatar
There is a post on here somewhere that used the same unit. He put it under the molding that the front visor runs in. I have had mine off to run new tv hdmi lines and it looks to have room for that kind of mount.
Newellri is offline   Reply With Quote
Old 11-23-2012, 07:11 PM   #7
Newellri's Avatar
There is a post where someone used the same unit. He put it behind the molding that the front visor runs in.
Old 12-06-2012, 10:40 PM   #8
Newellri's Avatar
I emailed FR and they suggested going thro top of mirror.
Old 12-07-2012, 04:23 AM   #9
cardinal4fun's Avatar
A few years back I mounted the NGP behind the drivers side and before the slide out. The hardest part was drilling the first hole. I put tape on both the inside and outside area where the holes were to be drilled. Once the bracket was bolted to the side of the unit and the coax run I went to Lowes and purchased a white plastic 4x4post cap. and a piece of plastic "u" wire hide material. The post cap I glued to the inside of coach, this covered up the ends of the bolts, and the "u" channel had its own glue so no problem. Once finish looked liked it belonged there.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 12-11-2012, 07:17 PM   #10
kenandterry's Avatar
X2 what cardinal4fun said for installation location and the "covering up" inside.
The side location positioning was determined by the fact that I didn't want the antennae any higher than the rooftop A/C units. My in-dash radio antennae (factory installed by FR) is like a curb-feeler for me as to my MAXIMIUM height underneath anything.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
antenna
