Old 08-11-2015, 07:58 PM   #1
Installing land line at home
I just purchased a motor home with a 30 amp requirement. I am looking for advice on installing a line at home to plug the MH into. I understand the 30 amp circuit in the box and the required end plug hut what type of wire should be run? Is there a limit to the length that should be run?
Jasandfam is offline   Reply With Quote
Old 08-11-2015, 08:14 PM   #2
fast murray's Avatar
If it is to be inside wiring you can likely get by with 10-2wg NM-B cable which everyone calls Romex. Try to keep it under 100 feet or you should upsize it to 8-2wg. If there will ever be a 50 amp camper on the horizon you might want to consider putting in 8-3wg so you can upgrade your receptacle when the time comes. This is what we'd do where I live and your local codes may vary. Obviously if the wiring is to be run on the outside of a building or if it needs to be protected from physical damage it would need to be run in the appropriate conduit and if it is to be buried it'll need to be run in a direct burial cable or in PVC conduit.
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 08-11-2015, 08:29 PM   #3
I found an article in the library here that you can print out. I am getting estimates tomorrow for the same thing, can't do that stuff myself, darn it
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 08-11-2015, 10:56 PM   #4
7 Year Class A RV'er
Good advice from fast murray. When I had power put in for our 30A MH, I went ahead and put in a 50A service and used a 50-30 adapter. Bought a new MH in April and it's 50A; no sweat, all ready for it!
2015 Legacy SR340 360RB
Old 08-12-2015, 11:26 AM   #5
Earlier post may help.
http://www.forestriverforums.com/for...amp-86372.html
mike.t is offline   Reply With Quote
Old 08-12-2015, 11:47 AM   #6
You need 6 ga minimum for 50 amp - wire size and type depend on length from panel and conduit or direct burial etc. I just put in an Eaton Rv 50/30/20GFCI power box from Home Depot. Nice box. My parking area is 165 feet from sub panel, so a pretty big job.
I used 4 ga in conduit.
2014 Ram 2500 Bighorn CC SB CTD 4X4
2016 Flagstaff 8528IKWS Platinum
2013 Keystone Hideout 23RBWE -Sold
randygk is offline   Reply With Quote
Old 08-12-2015, 05:01 PM   #7
Leatherman's Avatar
I followed the instructions here: http://www.forestriverforums.com/for...let-27223.html
And had it wired in and working in 30 minutes.
I used the items listed plus 35 feet of so cable 10 ga with a squared D brand breaker, and a weather proof box and it was $98 for all. Simple directions on the PDF.
I chose the flexible cable instead of hard wiring it so I could move it around if I moved my TT.
Bobby
2021 Nights Camped 53
2020 Nights Camped 44
2008 Rockwood Freedom 1640LTD
2016 Ram 2500 Tradesman CTD
Leatherman is offline   Reply With Quote
