Old 10-01-2016, 06:35 PM   #1
Is an inlet water filter a good idea
We recently bought our first motor home - Forester MBS 2401W. It has a water filter inside the cabin, but I was thinking a second filter, to minimize sediment in the drinking water tank, wouldn't be a bad idea. I purchased a Camco online filter, but it clogged and reduced the water pressure quite a bit. I have noticed a number of RV's with the outside filter, but most don't. Any recommendations would be appreciated.
CarolinaBlue is offline   Reply With Quote
Old 10-01-2016, 06:46 PM   #2
Old Camping Squid
Eagle-751's Avatar
A good quality water filter should be enough, I have a good .5 micron filter that does a great job, I would not add another to it. Good luck!
2006 F150 Supercab 5.4 Flex Fuel
2006 BRP Outlander XT
2009 Forest River Salem 30QBSS
2005 Club Car President
2002 Ezgo Limo, 2001 Ezgo
Eagle-751 is offline   Reply With Quote
Old 10-01-2016, 07:45 PM   #3
2012 Solera
Several members have reported their fresh water tanks filling and overflowing when attached to city water. Cause is apparently a check valve integral to the water pump hanging partially open. I have suspected that this might be from dirt or sediment in the unfiltered city water, which goes through this valve (as I understand the plumbing) before going through the in-house filter. I therefore do use both - a blue inline filter on the hose bib and the in-house filter. I believe the hose bib filters are somewhat coarser than the in-house, but should keep the worst of the crud out of the check valve.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-01-2016, 08:06 PM   #4
dan-nickie's Avatar
I use a water filter on the spigot even though I have a house filter.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 10-02-2016, 08:39 AM   #5
Hose Pre-Filter - yes/no?
I like the idea of removing any sediment with a pre-filter but after a week using the blue Camco filter in various campgrounds we had no pressure for the shower. We had to turn on our water pump. I suppose the clogged filter indicates it was doing its job. Has anyone else had a problem with reduced pressure caused be the hose bib filters?
Old 10-02-2016, 08:56 AM   #6
SeaDog's Avatar
I moved my in house filter to the outside and mount it to the bumper when hooked up.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-02-2016, 01:18 PM   #7
sfsgm's Avatar
You can hook up a makeshift filter using screens similar to those found in household faucets to catch the largest of the materials that may be coming out of the hose bib. Look at the screens that are probably on your sink faucets in the kitchen and bathroom(s) or the types of screen that you find hooked to your washing machine hose. This will give you some idea of the filtering quality. They are very inexpensive. Your washer may have a "cone" shaped filter. We have a well that furnishes water so we need it but if you have "city" water you may not have this type of filter. Just go to a big box store and you'll find them usually in plastic bubble wraps with several in them.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 10-02-2016, 01:20 PM   #8
Left Coast
This unit didn't come with a filter, so I added one from Home depot that sits on rear bumper and filters all water coming in.....
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 10-02-2016, 01:24 PM   #9
2012 Solera
Still on my first Camco hose bib filter. About 200 nights camped with it. I carry a spare in case it plugs up. If yours plugged up so quickly, I would agree - it protected you from a lot of crud.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-02-2016, 01:37 PM   #10
Cyber Phrenologist
Radio's Avatar
I have never had a problem with using a CAMCO or other external filter along with my built in under-counter filter. I usually run them both.
I like the one-piece disposable outdoor filters. Since it almost always requires 2 25ft hoses to hook up my trailer (inlet is in the back) I put the filter between the two hoses and let it lay on the ground, not bothering to support it with anything.
Disposable is good.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
water, water filter
