Old 03-17-2018, 06:13 PM   #1
Is something wrong
When the furnace is on... The air conditioner .. comesbon and draws the air out..
colourful64 is offline   Reply With Quote
Old 03-17-2018, 06:18 PM   #2
Flybob's Avatar
If you have a Dometic Thermostat. Move to the fan function and select Auto. The thermostat is designed to run the AC fan ( not compressor) when in Low or High setting to assist in circulating warm air near the ceiling.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-17-2018, 06:29 PM   #3
Ok thank you... Problem solved... This is the first time in it since October ... And I forgot about the auto
