Old 10-03-2015, 08:25 PM   #11
Bilcin's Avatar
Originally Posted by dcheatwood View Post
My oven, stove, microwave and frig are in one slide along with television and fireplace. Only problem I've had is in keeping the frig cool. It can't vent the heat as well with the upper vent in the sidewall as it can with roof vent. Still love the setup. Rockwood 8282ws. 2013.
I have the same problem with my 2015 Puma 32DBKS, frig will not cool below 66 degrees!!!! This is with a fan kit. The air circulation is insufficient with the set up.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 10-04-2015, 08:50 AM   #12
davidjb's Avatar
I put hinges on my doors...cooling fans never come on..rain stays out
davidjb is offline   Reply With Quote
Old 10-04-2015, 09:02 AM   #13
Wolverine 1945's Avatar
We had a 2005 Flagstaff TT with Kitchen SS,,, Kitchen & Sofa !!!
Never had a problem,,, loved the layout !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-04-2015, 09:01 PM   #14
dcheatwood's Avatar
Great idea!
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 10-04-2015, 10:24 PM   #15
deartruc's Avatar
I don't have a MH, but if you have this hose bracket, keep an eye on it. I had to do the zip ties so I can use it next weekend.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-05-2015, 04:34 AM   #16
Probably unrelated but, I have 2016 25dks with kitchen and sofa slide. After 5 trips, the slide-out motor failed. Camper has been in the shop since September 15th. I am concerned that slide-outs in general are prone to failures. Since this happened I am trying to learn as much as I can about how to care for them and manually operate them in case of failure.
2016 Micro Lite 25DKS, 2015 F250 6.2l Lariat 4x4 3.73's
rmillermtsu is offline   Reply With Quote
Old 10-05-2015, 05:07 AM   #17
Sounds as if we should be careful & not use slides anymore than we have to ???
Old 10-05-2015, 07:40 AM   #18
At the very least, not until we get rid of that nasty mud dauber infestation in the garage.
Old 10-05-2015, 07:49 AM   #19
halla's Avatar
We had a 2014 Thor with a full wall slide. Kitchen sink etc. was in the slide. We had a leak, but it was a bad fitting where they tied the outside shower into the plumbing under the sink. Our Dynamax has two slides, but no plumbing in them, makes me a little more comfortable.
We have had the slide room on the Dynamax fixed twice this summer, both slide motors failed, powergear.
2016 Dynamax Force. Just-Rite2
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 10-05-2015, 08:05 AM   #20
PhoneDude 8289's Avatar
We have a kitchen slide with the stove and fridge built into it. No problems with plumbing or electric but the fridge would not keep up in 85º + temps. Vent in the slide mounted fridge not great from FR. I added fans and a shroud in the top vent on the slide. 100º outside, 2º freezer, 34º fridge.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
slide
