Old 11-26-2018, 02:02 PM   #1
2manytoyz's Avatar
LED Step Lights - Installed
We recently purchased our Georgetown and discovered on the very first trip how dark the inside steps were at night.
I found some discreet lighting on the M4 LED website.
1 Inch Round Flush Mount Accent Light
Holes are drilled in the face of the steps, the wiring is pushed through, then the light is press fit into the hole.
I didn't like that there wasn't a threaded nut on the backside for a secure mount. Instead, I used a little hot glue on the interior flange to hold them in place, then I put clear RTV on the back of the LEDs. They aren't going anywhere, and are now watertight.
The other thing I didn't like was the oversized logo on the lights. No option to buy these without it. I used an oil based paint pen to black out the lettering.
Steps at night looking downward:
Really pleased with how they perform. The housing is aluminum, and appear to be a quality product.
This brand of LED products was found on the RVGeeks YouTube video.
Save 5% on your entire order with coupon code “RVGEEKS5“
I have no affiliation with anyone, or any product.
Robert & Dawn
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
https://www.2manytoyz.com/
2manytoyz is offline   Reply With Quote
Old 11-26-2018, 03:16 PM   #2
Just as confused as you
Scrapper's Avatar
Looks great!
Richard & Jill
Old 11-26-2018, 03:32 PM   #3
Kanadian Kamper
kenandterry's Avatar
........but but but but, no lights on the outside steps?
Ken and Terry
kenandterry is offline   Reply With Quote
Old 11-26-2018, 03:36 PM   #4
Multi-Slacker
What did you hook into for the power?
Safe Travels
CurtPutnam is offline   Reply With Quote
Old 11-27-2018, 03:37 PM   #5
2manytoyz's Avatar
The outdoor steps "do" have a light, but leaves a lot to be desired. I think I can fit these same LEDs in the face of each of the metal steps. Need to measure it and examine the underside of the steps to make sure there's no mechanical interference. If it's doable, I'll order 3 more and update when complete.
Robert & Dawn
Old 11-27-2018, 03:58 PM   #6
2manytoyz's Avatar
There's a control panel by the entry door inside. I removed the panel to see what my options were.
The switch on the right controls the LED patio awning light. The orange wire is hot, the white wire ground, and the blue wire is switched and goes to those LEDs.
The control panel looks like it's on a pedestal, but it's really a wire conduit, leading to the battery compartment.
I dug through the split looms until I found the blue wire, and verified the power switched on/off with the patio LED lighting.
The test light I recently bought has a built-in needle probe to stab wires. It's so fine/sharp, it leaves almost no visible hole when removed. To use it, connect the built-in alligator clip to a ground source, hook the probe over a wire, press the handle to stab the wire. If there's 12V available, it will light up. I keep this tool on the RV now. If you press the handle, with no wire in the hook, the needle projects out the end of the hook, allowing much fatter wires to be tested without the need to fit in the hook end. Like most everything else I buy, found it on Amazon.
https://www.amazon.com/gp/product/B077D5FWV7/
Hope that helps.
Robert & Dawn
Old 11-27-2018, 05:18 PM   #7
Nice project, well done. Nice to make climbing steps a little safer.
Rick & Judy & Buddy the Wonderdog
Coachmen 321 FEDSLE ProPride Hitch
2016 Ford F150 Lariat Supercrew 3.5 Eco Boost
Tow Haul 3.55 rear
Hingham, Mass.
capt104 is offline   Reply With Quote
Old 11-27-2018, 06:37 PM   #8
CZNEDY's Avatar
Nice job. Good project for me to do over the winter. Bought some today. Thanks for sharing
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 11-27-2018, 06:42 PM   #9
tjo
Nice clean install.
5th Wheel: 2016 Wildwood Heritage Glen 286RL
Tow Vehicle: 2017 Ford F250 SD 6.7L Lariat CrewCab
Hitch: Pullrite ISR SuperGlide 16K
tjo is offline   Reply With Quote
Old 11-27-2018, 06:46 PM   #10
Very nice!
2rad4u is offline   Reply With Quote
Old 11-28-2018, 10:32 AM   #11
great job
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 11-28-2018, 09:41 PM   #12
Villagerjjm's Avatar
My Rockwood Ultra lite came with the step lights installed.... a great convenience, but yours look like they put out more light. Nice!
Villagerjjm is offline   Reply With Quote
Old 12-02-2018, 11:03 PM   #13
2manytoyz's Avatar
Just a quick update. I ordered 3 more of these lights for the outdoor metal steps. Once they are installed, I’ll post another update.
Robert & Dawn
led, light
