Old 11-13-2018, 08:49 PM   #1
Letting motor run
I have a 2018 diesel Isata 3 parked for the winter in Florida. I was wondering how often should the motor be started and how long should it run?
Bethey is offline   Reply With Quote
Old 11-13-2018, 08:57 PM   #2
DieselDrax's Avatar
Donít start it unless youíre going to drive it for 30+ minutes. Fresh fluids and connect the batteries to a Battery Tender, then let it hibernate.
Running it and letting it idle without driving it to get all the fluids up to temperature for a while does more harm than good.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 11-13-2018, 08:58 PM   #3
Crusadernoob's Avatar
If you only leave it for a couple months, no problem, it is worse to run it and idle it. Either leave it alone or go drive it and get it to operating temperature.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 11-13-2018, 09:32 PM   #4
When starting it up to drive it should I let it warm up or just take off?
Old 11-13-2018, 10:52 PM   #5
Let it run a couple minutes and drive off, just don't abuse it, no high rpm's until warm, this goes for any engine.
