Old 05-01-2018, 10:21 AM   #1
Levelers, setting '0'
Hey Guys,
Quick question. When you are setting your '0' point for your leveling system (or in my case my LevelMate), if you have a full wall slide (or in my case 2 slides on the same side), do you find it helpful to have the slide side raised up a little to counteract the natural sag that happens over time? In my older Greyhawk I found that over time the coach would drift a little low on the slide side over time; my assumption being the weight on that side caused the suspension to sit a little more after awhile or my levelers sunk a little more.
Thanks !
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 05-02-2018, 02:43 PM   #2
RedLdr1's Avatar
That has been my experience. When we had our 2400W full wall slide on the drivers side I found that my "Zero" was +2-3 degrees. If I didn't park so the drivers side was up a couple degrees I'd get a noticeable sag after a couple days.
I plan on starting with a +1 degree setting on our 2500 as the slides aren't as heavy as in the 2400W or in your 2420....
Wayne and Christine
2020 Sunseeker MBS 2400Q Trekker Cap and Metallic Full Body Paint
2019 Ford Ranger Super Crew Lariat 4X4
RedLdr1 is offline   Reply With Quote
Old 05-03-2018, 06:55 AM   #3
Looks like this time I'm going to set my '0' a little high on that side and see how it goes. Thanks for responding !
