Old 06-23-2018, 08:56 AM   #1
cavie's Avatar
MH classes
We have class A and Class C. What is a Class B?.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 06-23-2018, 10:47 AM   #2
A Class B RV is contained within a standard van body, although often with an extended roof. A B+ has a slightly wider body behind the van nose.
stephndudb is offline   Reply With Quote
Old 06-23-2018, 11:00 AM   #3
wmtire's Avatar
This is a breakdown of some RV types.
https://en.wikipedia.org/wiki/List_o...ional_vehicles
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 06-23-2018, 12:17 PM   #4
Also Super C is a C style body/cabin mounted on a heavy truck chassis.
sask is offline   Reply With Quote
Old 06-29-2018, 12:10 AM   #5
Is a Dynamax type RV a Super C?
EricNJ is offline   Reply With Quote
Old 06-29-2018, 01:11 PM   #6
They make both C and Super C.
The C class will be the ones on the E450, Mercedes and Ram chassis. The Ram chassis does have higher GVW of 19,000 lbs than the other 2.
The Super C will be on the Freightliner chassis with GVW of 33,000 lbs.
Old 06-29-2018, 10:51 PM   #7
Got it! Thanks!
Old 06-29-2018, 11:08 PM   #8
Glad you got it.
I could have made it simpler if I had of said that it uses the Freightliner chassis and cab.
Old 07-02-2018, 10:27 PM   #9
All good. Thanks!
Old 07-09-2018, 07:04 PM   #10
Lacey's Spring, AL
formerFR's Avatar
yep, the 'semi truck' front look is what gives away the freightliner SUPER C class, as it is truly the 'diesel' puller of the RV world.
The Class C's can get more confusing, trying to 'differentiate' between Cs, B+s, and others is a class in itself.
a Class B should be one, such as a Mercedes Sprinter, that is not really 'modified', as far as the body goes, and is just retrofit on the interior. But, even some of those have changed over time. Extended roofs, slides, etc. These have more of the 'personal Van' front look.
a Class C is probably the hardest to pin down since it can really be several different things, though it is 'supposed' to be: a manufactured Chassis(driver area only), typically a ford or dodge, an 'added on' RV body(built in the RV factory), and possibly slide rooms. These have more of the typical 'cargo van' front look.
Class As are the easiest to identify, most of the time, but even they can get confusing as to which are Ford chassis'/engines or which are Freightliner(or Spartan) chassis'/diesels engines(rear mounted), or even some diesels that are either front mounted, or even mounted nearer the middle!
As much as we want it to be, it's not as a 'standardized' world as we may want it to be. We, the public, keep asking for new and better... and they keep giving it to us!
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 07-18-2018, 03:18 PM   #11
GM
bclemens's Avatar
Don't forget the B+ (Lexington, Concord, Used to be Jayco Melbourne). That is what they call a C, without the cabover bed and narrower body (typically 96") versus a traditional Class C at 102".
Technically there are ONLY 3 classes. Class A (named for the A rail they are built on). Class C (for Cab Chassis) and Class B (which is a VAN body, but I have no idea how it got the name)
Super C, B-Plus are just industry terms to try to differentiate between a traditional Class C.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
