Old 10-07-2016, 04:18 PM   #1
redcloud1's Avatar
Need an answer to a question about odd smell on in the water
What would cause the water when you fill your holding tank to have a sulfur smell to it. We added bleach to the tank and sterilized it before feeling it this time and it still has a rotten egg smell to it
redcloud1 is offline   Reply With Quote
Old 10-07-2016, 04:22 PM   #2
BamaBob's Avatar
What kind of water source are you hooked up to ? (Sounds like maybe a well)
We use a 2 stage filter system: Sediment and then a .5 Micron Charcoal filter and then the whole house filter on the Coach. Perfect water every time
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 10-07-2016, 04:31 PM   #3
Iwannacamp's Avatar
Could it be coming from the water heater? Seen that many times(on residential)
2017 Puma 297RLSS
Old 10-07-2016, 04:49 PM   #4
redcloud1's Avatar
Marianna State Park we filled the tank from their water hookup and nobody else is having the problem except for us.
Old 10-07-2016, 05:00 PM   #5
Herk7769's Avatar
The rotten egg smell comes from a bacteria.
You will need to use a more highly concentrated Bleach solution (1/2 cup bleach per 40 gallons), run through ALL your pipes and water heater till you smell bleach at each faucet, and let it soak for at least 24 hours.
Close the winterization valves! (Important step) AND TURN OFF THE AC TO THE WATER HEATER.
Drain all the bleach water out of your fresh water tank, and low point drains.
Fill fresh water tank with water and flush plumbing well (Leave the water heater isolated with the bleach solution for now.)
CAREFULLY open the outside water heater drain and drain from that. This way no sludge will get into your inside pipes.
Replace the drain plug and open the isolation valves.
Fill with fresh water before restoring AC power to the water heater.
You can add Baking Soda (not powder) if the chlorine smell in the water is not to your taste.
Hope this helps
Herk
Name:	Odor From HWH.jpg
ID:	122355   Click image for larger version
ID:	122357   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-07-2016, 05:02 PM   #6
Flybob's Avatar
The smell could be from the last fill up. You can never get all the water out of the FW tank when you drain it. If the water that was sitting in the tank has dissolved sulfur, nitrates or minerals, it will react with bacterial and create SO2. When you fill the tank next time, the incoming water will drive the SO2 out the vent. If you want to see what is going on. Fill a glass from the suspect water source. Let it sit in the camper in a dark area for a week or two. Then check to see what it grew. Many camp grounds have wells.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-08-2016, 01:50 PM   #7
Stinkey water
Could be water heater. May be bacteria in there as well. Had that at home in my upstairs water heater as it was turned off for long periods of unuse. Would have to run lots of water through it to flush it out. Decidednto leave it on, problem solved. Heat killed bacteria.
pdqparalegal1 is offline   Reply With Quote
Old 10-08-2016, 02:41 PM   #8
If you have an anode rod in your H2O heater replace the magnum one with an aluminum one. Maganesium and sulfur have a reaction. One of your last fills of H2O probablity had sulphur in it. Please read advise below.
Very often, replacing the standard magnesium or aluminum anode rod with an aluminum/zinc alloy anode will solve the problem. The zinc is a key ingredient, since pure aluminum anodes will also reek to high heaven. Also, some people use the terms aluminum and aluminum/zinc interchangeably. It's important to be specific or you won't solve the problem.
For most folks, an aluminum/zinc anode is the cheapest fix for this problem and we suggest that you to try it first before considering the alternatives -- unless you soften your water.
grouchmore is online now   Reply With Quote
Old 10-10-2016, 02:42 PM   #9
Two things to try. If you have plumbing to a washer and don't use it, flush the lines occasionally. Not doing so will cause fresh water to smell. Second drain the hot water heater and fill with fresh water. I discovered I needed to drain my water heater after every trip or it caused the water to smell if I left water sitting in it for even a few days.
bobneal69 is offline   Reply With Quote
Old 10-10-2016, 08:09 PM   #10
Rotten egg smell
I had this problem and tried everything mentioned in the previous posts. I finally solved the problem by replacing the anode rod in the water heater. I now replace it regularly as well as sanitize the entire system a couple times a camping season. So far so good. I also found a second low point drain immediately under the residential refrig that I drain frequently.
levert is offline   Reply With Quote
water
