Old 05-19-2015, 04:47 PM   #11
Herk7769's Avatar
Putting the batteries in backwards (even momentarily) will blow the two reverse current fuses. (Typically 40 amp orange fuses)
I would also check the wire from the converter to the AC fuse panel connection before I gave up on the converter. A loose wire can corrode/burn to the point where it is not making contact.
HAM CALLSIGN - KC3FFW
Old 05-21-2015, 01:33 PM   #12
halla's Avatar
Our new Force lost all the lights inside, it has three fuse panels, two inside one of the baggage bins and one under the bed, after pulling all of the fuses, it was one under the bed causing the loss of interior lights and the Main/Storage switch that lights up red. I thought it was the converter, but just a fuse. Hope that helps.
halla is offline   Reply With Quote
light, motorhome
