Old 05-17-2015, 11:08 AM   #1
No Lights inside motorhome
We are hooked to shore power, (50 amp).. Inverter went off sometime in last week. AC items work (Ref./microwave), but we don't have any lights at all. Plus the switch by front door will not turn on (store/run). Do have power at the
120volt plugs. We have motorhome in building and can't get slides in, so we can take it to a repair shop.
stephaniegary is offline   Reply With Quote
Old 05-17-2015, 11:15 AM   #2
bubbles's Avatar
Sounds like your converter has gone south. You could possibly use your emergency start switch to power the unit with 12 volts to get the slides in.
Old 05-17-2015, 11:17 AM   #3
Would check fuse panel as well
brandonelderCO is offline   Reply With Quote
Old 05-17-2015, 03:03 PM   #4
7 Year Class A RV'er
You didn't mention a year or model, so this may be way off, but it sounds like all you've lost is 12V power. Two things I would check:
1) If you have an electrical control center, check the 12V breaker. It's usually a very small black button on a white circuit breaker at the lower right of the ECC when looking at it.
2). Assuming you have multiple coach batteries, try bypassing the one closest to the coach. If it has dead cells, etc., it could be keeping power from reaching the coach.
Hope this helps. Good luck.
2015 Legacy SR340 360RB
Old 05-17-2015, 03:31 PM   #5
Can start RV, But will not let slides come in with motor running. Diesel will not stay running (starts with AUX Power Button) then shut down after letting go.
Old 05-17-2015, 03:43 PM   #6
A converter is basically a high duty cycle battery charger. Hook up a car charger to your coach batteries and see if they will take a charge. If not replace them with new so you can get it to the shop.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 05-17-2015, 04:13 PM   #7
bubbles's Avatar
Don't start the coach just hold the aux power button on to see if the slides will come in. Typically the slides can not go out with the engine running but do come in with it running. Your coach is a different breed than what I am used to. The aux switch ties the house and chassis batteries together and thought there was not sufficient coach battery power alone for the slides.
Old 05-18-2015, 12:31 PM   #8
Take simple step first...check fuses on converter.
I lost power in my Wildwood to all my DC functions. Ended up being nothing more than the two 30 amp fuses being blown. Replaced, and fine ever since.
rpatterson is offline   Reply With Quote
Old 05-19-2015, 04:30 PM   #9
I had something like this happen last year in our Sunseeker 2450S. My converter had two fuses and one was blown. They were a strange size but finally just replaced both with correct ones and have been fine over a year.
markangie24 is offline   Reply With Quote
Old 05-19-2015, 04:39 PM   #10
Of just retract your slides manually.
rana is offline   Reply With Quote
light, motorhome
