Hi, I have a FR3 32ds with a vehicle weight around 20,000 pounds
What do y’all use to lift up the front of the motorhome for an oil change?
On level ground can I just use my hydraulic jacks and place wooden blocks under the tires or should I make ramps using stacked two by eights or are there recommended premade ramps? Thx
I made mine for Forester class C out of 2x10's stacked 3x with a 2x4 stopper, works great to change oil, plus it helps to keep the MH level.
I made 2 sets so I could use them on the rear
I park mine over a dip in the yard... Plenty of room to get under there, once I get past the front air dam! BTW I am 6'-2" 225# so I ain't no little skinny guy!
However a set of ramps made out of 2x8's isn't a bad idea, just make sure to chock the rear wheels!
I made mine when I replaced the sway bars, shocks (rear) and added a track bar. Plus they work great changing the oil in my F350, which is lower in the front..I not a small guy either 6'1 222lbs...and 64
easy to get down, slow to get up
I just take a little pressure off the springs with levelers. Fumoto valve and a punched hole in the filter does the rest. Actually there is a lot of clearance even without the levelers.
I noticed an add on Kijiji for some free lumber. There was some 2x4, 4x4 and plywood... enough to make some RV ramps. I based the shape off of my plastic ramps. I designed the ramp in 2 parts so that I could remove the ramp once the RV is on the platform part of the ramp. I used a piece of rebar to hook the 2 parts together. I used them today. They are pretty ugly but functional.
Very nice ramps. Levelers are soooo convenient and tempting. But...... there is always a risk, even if it’s a small one, that anything mechanical can fail. I had to build a set of compact ramps by stacking and stair stepping 3/4 exterior plywood to provide 6” of lift onto the dolly ramps when loading the Toad when I was dollying. We flat tow now, but I use these ramps to raise the front or rear of the motor home 6”, which is just enough, when needed.
Zero risk.
