Old 07-15-2019, 12:29 PM   #1
Dodge Guy's Avatar
Outlet for small compressor
Hello. So I have a small 2 gal compressor to fill tires and other things and to use as a storage tank for my 12V air horn compressor and tank. The 12V compressor only runs when the ignition is on. And the 110V will only run when it’s needed to fill things, I don’t want to over heat the small 12V compressor and I got the 110V for free. Where would be the best place to pull the power for the compressor? Should I pull it from the breaker box? Or should I tap off another outlet inside?
Has anyone done something similar? Don’t want to make it a huge project. I do have an outlet on the other side of the storage bay that I could just plug into when I need it. Right now it powers an LED TV, small fridge and an ice maker. Or maybe even use an extension cord to the pedestal when at a campsite.
Anyone?
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-15-2019, 12:49 PM   #2
CincyGus's Avatar
I would choose the latter. Plug in when you need it either on the campers outlet or the pedestals 20 amp plug. Why make it more complicated than that?
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 07-15-2019, 09:02 PM   #3
Dodge Guy's Avatar
Yes, the more I was thinking about it that is what I’m going to do. Much easier than trying to run a new circuit.
Old 07-15-2019, 09:13 PM   #4
Coach
Guessing your rig has a generator, you should have access to 120v whenever you want. Stay simple and plug in when and where needed.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-16-2019, 01:54 PM   #5
I have a small compressor with a long hose in the front compartment of my 5er. Since I carry a 120v extension cord any way, when I need air I simply plug the cord onto the exterior 120v outlet and inflate away.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 28 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
