Old 09-30-2015, 01:00 PM   #1
KAS
Exclamation Parking in Sloping Driveway
Unfortunately my driveway slopes quite a bit. Needless to say, I can't run the refrigerator there and everything slides off the table and counters . I was thinking of driving it up onto something to level it when needed. It is parked nose down, so only the front wheels would have to come up. In campgrounds I use Lynx levelers, but I couldn't use them here because they would have to be stacked too high. Are there any sturdy ramps out there that would be able to support the front end of a Sunseeker of approx. 14,000 lbs? My fear is that they might collapse and/or tip sideways. And wooden ramps would either be too narrow (again, danger of tipping over) or, if wider, weigh too much to be moved. Has anyone out there had the same problem and was able to come up with a workable (and safe!) solution?
KAS is offline   Reply With Quote
Old 09-30-2015, 01:04 PM   #2
TURBS's Avatar
How much height do you need?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-30-2015, 01:19 PM   #3
KAS
A little less than 2 feet.
Old 10-01-2015, 06:21 AM   #4
trdutch's Avatar
My drive slopes and I use the Big foot Levelers (SunSeeker 2860)
I back it down and on manual,I raise only the two Back jacks
It's not perfectly level but close enough for the Fridge to work and slides to be extended
With the slope you have I would use 2or 3 blocks under the Levelers and chock the tires
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 10-01-2015, 07:30 AM   #5
waiter21's Avatar
raising the front tires two feet to make it level is a lot. Airbags or jacks would be a good first choice.
To get an idea what this might look like I drew up a 16 inch high ramp that is a little over 5 ft long. You would need 4 2x8 that are 8 ft long. (assume the 2x8 are 1 5/8 thick) for each ramp. These would be heavy.
Regardless, I would chock the rear wheels to make sure it cannot roll down the drive.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-01-2015, 12:03 PM   #6
slopping driveway
I live in Canada and have the same problem as you. I went to Canadian Tire an bought ramps that hold my Sunseeker 2500TS and bring it level enough for my fridge to work. the RV still slants down but not so much that flat objects stay put but round ones roll off.
papakilo is offline   Reply With Quote
Old 10-01-2015, 12:26 PM   #7
Don't use standard automotive car ramps designed for light trucks and passenger cars. I witnessed those collapse when I guy was using them at a campground with his Georgieboy Pursuit. I don't know the weight, but he was trying to drive up the ramps going forward. He had a Ford Triton V10 engine and it was too much weight. No one was hurt and no damage was done, but the ramps folded like they were made of aluminum foil.
Matt
2013 F150
2014 Salem Hemisphere 282RK
Lowes48fan1 is offline   Reply With Quote
Old 10-01-2015, 12:46 PM   #8
To use driving ramps you would need heavy duty truck ramps I have a set and they are rated at 20k pounds. But they will only lift you about 12 to 14 inches.
j free is offline   Reply With Quote
Old 10-01-2015, 12:48 PM   #9
KAS
How high are they? The highest heavy-duty truck ramps I could find online are only 9.5" high. With several boards I could raise that to an acceptable level. Unfortunately Class C Sunseekers are lower in the front anyway (in campgrounds I usually have to drive up on Lynx levelers, since I don't have any hydraulic levelers like Bigfoot) which I have not even taken into account, I only measured the driveway angle from wheel to wheel. I am past caring what it would look like from the street, like a MH on stilts?
Old 10-01-2015, 12:50 PM   #10
KAS
14 inches and a couple of boards would work, where can I find those ramps?
parking
