Old 08-02-2015, 03:15 PM   #1
Putting washer/dryer combo in Sunseeker
Has anyone done this in a 3170ds? What kind, where in rig, how was installation, do you like it? I'm looking at the LG combo at HD. I hate laundromat s !
2014 Sunseeker
3170ds (Suzuki Samurai 1986 toad)
Gary and Dottie, fur babies Doodle(corgi) and Beau(yellow lab)
Yorkranchgalnguy is offline   Reply With Quote
Old 08-05-2015, 08:16 AM   #2
Boso's Avatar
I guess you will have over 2000$ in it when finished plus the loss of room in rv. Makes me like laundry mats little more for a couple times a year. But if I did it the combo you are talking would be a good one
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 08-14-2015, 01:01 PM   #3
Bought the LG combo-now to get it in the MH! It's 27" wide. Won't fit through the door. Anybody removed large rear window for this? What about emergency exit window at head of bed? Will that work with over head cabinet there? Any body have any ideas-all thoughts appreciated!
2014 Sunseeker
Old 08-14-2015, 03:10 PM   #4
Boso's Avatar
Lg washer&dryer
If I did not carry it back I would take the lg apart to make smaller and carry in that way or hire a appliance repairman to do it
Old 08-14-2015, 05:37 PM   #5
Here's an idea. Try the Ford cab doors. If really desperate you can remove the passenger seat and/or a cab door.
Last result would be to completely remove one of the slides.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 08-16-2015, 11:24 PM   #6
Won't fit thru cab door because of dash. Any body ever removed back window then re installed? Any other ideas?
2014 Sunseeker
Old 08-17-2015, 01:30 AM   #7
Crockett's Avatar
large windows are common to remove. just gett a measurement to be sure it will work.
Crockett is offline   Reply With Quote
Old 08-17-2015, 08:19 PM   #8
It should just fit through rear window. How do you remove it? After you unscrew the screws inside do you just push out from inside? Is there putty that needs to be removed befor re installing? What do you seal it with? My son and friends will be doing it so I just need to know what we'll be faced with, and what sealant to buy. Thanks for any advice.
2014 Sunseeker
Old 08-17-2015, 11:59 PM   #9
Crockett's Avatar
pull blinds and valance. pull screws and pry gently from outside. i reseal with butyl tape. trim excess with pen knife right away and then again after a few hours. slice excess vertically following frame and then pull excess off while you slice so it doesnt embed in siding. thats just my preferred way. dont like d foam or putty tape on clamp ring windows. caulk is not needed on butyl...if it has d foam, you could just replace and caulk. i like lexel for a caulk. found at ace. please get the hang of a fine bead before application. its kind of an artform. good luck...
Old 08-20-2015, 11:46 PM   #10
Thanks for the info, Crockett. Can't find butyl tape- stuff I found is called cord weatherstrip by MD. Will that work? The window is 1/4 " bigger than the washer/dryer! I'll let you know how it all turns out.
2014 Sunseeker
sunseeker
