Old 11-09-2015, 09:26 PM   #11
Removing Batteries for Winterization
Originally Posted by MNtraveler View Post
This is only safe if you have a converter such as the Progressive Dynamics that will switch to float/maintenance mode when the batteries are fully charged. If the circuit keeps full charging, the batteries will be fried. Some on these boards have reported doing just that. Check your converter manual or specs online to be sure.
A Berkshire has a inverter that will maintain batteries at a safe level. This is not a problem to do it in this way.
Not all Moho's are equipped that way so it's best to check with your dealer to make sure that you are not doing damage.
Old 11-09-2015, 09:34 PM   #12
MNtraveler's Avatar
That's either what I said or meant to say.
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-09-2015, 09:46 PM   #13
No problem. I was just adding the info about the Berkshire and a suggestion to check with their dealer. There are several different setups and as you said you can fry several hundred dollars in batteries.
Old 11-10-2015, 12:17 AM   #14
MNtraveler's Avatar
Seems we agree! I mention it because sometimes people see something and think, "oh, I'll do that." People like me!
2016 Forester 2401R
Old 11-10-2015, 06:47 AM   #15
I store inside and just disconnect the negative cable at the battery. There is always battery when I pick it up. I can't use a trickle charger where I store.
2014 XLR27HFS
2006 Ford F450 Diesel Dually
2015 Harley Freewheeler Trike (Tara)
2004 Harley Road King Custom (Gemma)
breezyhillfarm is offline   Reply With Quote
winter, battery
