Old 01-29-2019, 04:22 PM   #1
replace rear steel inner wheels
Had this originally posted under "Dynamax" forum but only got 1x response ( from 05CrewDually - thank you ) so thought I would try under this "General" forum to get more feedback hopefully :
Wondering if anyone that has the 4x factory option aluminum wheels on their Class C MH has replaced the 2x steel inner rear wheels with comparable aluminum wheels ? If so, what was the source of the 2x replacement wheels - Dynamax ? dealer ? wheel manufacturer ?
Did you encounter any unexpected problems or issues after installing the new aluminum wheels ? ( 05CrewDually raised the issue of checking stud length to compensate for the thicker aluminum wheel )
Thanks for your valuable input.
camperpapa is offline   Reply With Quote
Old 01-31-2019, 07:54 PM   #2
I had them on a f 350 the first time I rotated them I couldn’t break them apart from each other.
retired on a mountain is offline   Reply With Quote
wheel
