Just curious. I have a 2018 Class C Forester 3011. I noticed yesterday that quite a bit of cold air leaks out from under the large slide out.
Even a little from the bedroom slide. All rubber gaskets are in place. It's hot down here. When you get the inside fairly cool and go outside, you can really feel the air coming out. I certain I'll come up with a solution as I'm an avid "do-it-yourself-er". Just want to know if anyone else has noticed this. With the Texas heat, I need to keep as much of the cold air in as possible....
Thanks in advance...
