Old 09-15-2012, 06:24 PM   #1
(Solved) Please help, currently camping w/ no hot water.
I have a fr windsong and we are on our first outing and dont have any hotwater. I have hot water in the tank and I shutoff the bypass but still will only get a small trickle of hot water out any faucet. Any ideaswhat it could be? We need hot water. Thanks.
av8erdunn is offline   Reply With Quote
Old 09-15-2012, 06:45 PM   #2
bob213's Avatar
Clean out all the faucets to get rid of any construction debris. Check your out side shower and make sure the valves are off. Hope that does it. Recheck the position of your bypass valves.
bob213 is offline   Reply With Quote
Old 09-15-2012, 07:24 PM   #3
Herk7769's Avatar
Serioulsy. Check your shower hand wands. If the shutoff in the wand is closed and the valves are left open, cold water will cross over to the hot water side when you run the hot water. The effect is the same as leaving the bypass valve open.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 09-15-2012, 07:29 PM   #4
First of all, to verify water in the tank, pull the pop off valve, and make sure you get water out. If you have water there, make sure the water heater is lighting. You mention small trickle of water out of the hot faucet. When you first turn the hot water on, if it is hot, then turns cold, bypass valve is set wrong. Re check.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-15-2012, 07:31 PM   #5
Dave_Monica's Avatar
[QUOTE=av8erdunn;252406 I have hot water in the tank and I shutoff the bypass but still will only get a small trickle of hot water out any faucet. [/QUOTE]
As you're saying that you can't get hot water flow, have you checked to ensure that the supply and discharge valves to/from the water heater are fully open?
Dave
Old 09-15-2012, 08:16 PM   #6
Nigels's Avatar
Maybe a stupid question but do you have good cold water pressure?
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
Nigels is offline   Reply With Quote
Old 09-16-2012, 07:53 AM   #7
Thanks for all the replies. It turns out my neighbor is a rv guru; he came over and looked at it for me. The back flow preventer was messed up. We removed it and took the guts out of it and she is working fine now. Once again thanks again for the replies, the first trips are always a little tough.
Old 09-16-2012, 10:52 AM   #8
Nigels's Avatar
So not a stupid question after all! Glad you have found a solution, enjoy your camping
Nigel & Bev
