Old 02-11-2018, 09:41 AM   #1
Stablelize
Looking to find something to make camper more solid, the question I have is when the camper is set up stability jacks are down slide outs are out, when you walk in the camper you still get a lot of sway. Any ideas ?
fireman1969 is offline   Reply With Quote
Old 02-11-2018, 09:44 AM   #2
AquaMan's Avatar
Triangulation. There are several products out there that will help, but it wonít completely disappear.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-11-2018, 09:45 AM   #3
AlisonR's Avatar
I use these:Click image for larger version
Alison
AlisonR is offline   Reply With Quote
Old 02-11-2018, 09:45 AM   #4
Originally Posted by AlisonR View Post
I use these:Attachment 162166
I have these itís side to side sway
Old 02-11-2018, 09:46 AM   #5
AlisonR's Avatar
There are different brands out there. I have had mine a long time.
Alison
Old 02-11-2018, 10:06 AM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
I like the screw type bottle jacks under the frame at the wheel area. After setting up and level, slightly raise (about 1/4"), place the properly adjusted bottle jacks on 2X4s under the frame, and then slowly lower the landing gear to level. This is only for stabilizing !!! Additionally, I use my portable hydraulic jack (not jacked just screwed) for one of the screw jacks, I bought a screw jack from the junk yard for $5. Living the dream.
donanddona is offline   Reply With Quote
Old 06-02-2018, 06:30 PM   #7
XenoRev's Avatar
I add a set of these under my slide. Made a difference.Click image for larger version
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 06-02-2018, 06:37 PM   #8
Flybob's Avatar
Most recommend that you not use jacks under the slide.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-02-2018, 07:17 PM   #9
GOODBYE SUIT - HELLO RV!!
Using good quality wheel chocks tightened firmly eliminated the problem in my former campers with sway. No sway issues in our Rockwood!
HAPPIEST WHEN CAMPING!
2019 Rockwood 2104s ****
2017 Starcraft Satellite 16KS
2012 Jayco X23B Hybrid
2009 R-Vision C243S Hybrid
2006 Coleman Bayside PUP
HappyCamper1962 is offline   Reply With Quote
Old 06-02-2018, 07:38 PM   #10
XenoRev's Avatar
I know it's not common, but we had a bunch of wiggle side to side. My son flopped, as teens do, into the couch that's in the slide. I watched the opposite side tires lift and drop. Not off the ground, but significant flex.
So, added the two jacks. No more side to side wiggle.
2018 Salem 27DBK
2004 Ram Quad 1500
1986 Jayco1016PUP
Old 06-04-2018, 08:53 PM   #11
Valterra 020106 RV Stabilizer https://www.amazon.com/dp/B001UGJPXQ..._gYEfBbJWBYZ28
I have 2 of these and highly recommend them. I put one under the steps and the other going the other direction under the rear bumper. I have a 3010 with the big foot levelers, but still wasnít happy with the shake we got when walking around. These are extremely simple to set up and work great!
carol108 is offline   Reply With Quote
