Old 06-11-2014, 02:34 PM   #1
Switch question
Can anyone tell me why this light is on and if it's normal? Stays on while driving. Click image for larger version
Name:	ImageUploadedByForest River Forums1402515240.833179.jpg
TangoTango is offline   Reply With Quote
Old 06-12-2014, 09:17 AM   #2
Come on guys, someone must know. I can't find anything in the "manual".
Old 06-12-2014, 09:22 AM   #3
wmtire's Avatar
Tango, what make/model MH do you have?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-12-2014, 09:23 AM   #4
Kaadk's Avatar
Does it go off if you switch it? The lower 4 switches all show their lights off, but they're all in a different position. The exception is the switch next to it, the one that looks like a lightbulb, that's in the same position, but not lite.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 06-12-2014, 09:27 AM   #5
"14 coachmen encounter. The switch with the lightbulb to the right is the generator start switch. The switch in question that is has the green light can only be pushed on and is spring loaded to the off position when you let go. I believe it is a battery boost switch of some sort, but not certain and don't know what the green light is indicating.
Old 06-12-2014, 09:36 AM   #6
Kaadk's Avatar
Ah, ok, well, I have no idea what that switch does. In most cases with a momentary switch like that the light will indicate that whatever it is you've turned on is on. But the only cases for a momentary switch is if whatever it is that turns on will eventually turn off. Normally after some set amount of time or a particular event.
Hopefully someone else can hop in here.
Old 06-12-2014, 09:42 AM   #7
wmtire's Avatar
Great, since this may be a RV specific model question, you can also seek out fellow members who have the same RV for their advice.
Here is how:
http://www.forestriverforums.com/for...ile-53932.html
When doing the search, I would only put 'encounter' in the year/model box. I did this and got several members who have that listed in their profile. You can then PM a member with your specific question, and they may can help. I would limit the PM's to active members who have been on the forums lately.
Hope this helps, and another reason why it's good to put your make/model RV in your profile.
I did send a PM to one member for you.
Old 06-12-2014, 09:59 AM   #8
Thanks for your replies. I'm not that worried since the light is green, however I do need to know what it's for and how and when to use it. I wish they wrote better owner manuals, so things were easier to troubleshoot. Thanks again.
Old 06-12-2014, 10:03 AM   #9
redneck 92's Avatar
Switch Question
My Encounter has the same switch and has always been lit up.
2013 Coachmen Encounter 34TA
redneck 92 is offline   Reply With Quote
Old 06-12-2014, 10:07 AM   #10
Kaadk's Avatar
Just thought of something else. Does it turn off if you press and hold? Some switches you need to hold the button for a second or two to show you really want to turn off whatever and that it's not an accidental bump.
